Can anyone tell me that, is ssh is by default enabled in Jetpack 4.4 version? I am facing a problem that after flashing with Jetpack 4.4 for Headless mode not able to connect via ssh. The same thing is working fine with Jetpack 4.2.1.
Yes, ssh is enabled by default. Have you confirmed the device boots up already?
Sometimes it is possible the device fails to boot into kernel…
Check what the serial console says. See:
http://www.jetsonhacks.com/2017/03/24/serial-console-nvidia-jetson-tx2/
How to confirm device boots up or not as it is in Headless mode…
We use uart interface to dump the log. It is called log from serial console.
How about reading what linuxdev posted here?
