a simple question on the documentation is how to flesh the card in “Headless mode”, shown below:
Headless Mode Flow in oem-config
The IP address to connect to is not listed anywhere. I found this 192.168.55.1 by searching the internet. If I try to search for 192.168.55.1 in the documentation I get no results. Where can I find this information in an official nvidia documentation ?
Salvatore
you should use 192.168.55.1 if connecting through USB wire
as these are the default USB LAN addresses [ 192.168.55.1/192.168.55.100]
Otherwise, you may use any custom Ethernet LAN or Wifi IP addresses, given they got configured somehow by you manually [or by script] .
