Headless Mode setup failed
Software Version
[ ✓] DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[✓] Linux
QNX
other
Hardware Platform
[✓] DRIVE AGX Orin Developer Kit (940-63710-0010-300)
other
SDK Manager Version
[✓] 1.9.3.10904
other
Host Machine Version
[✓] native Ubuntu Linux 20.04 Host installed with SDK Manager
other
Good evening,
We successfully flashed DRIVE OS 6.0.6 and set up the kit. Everything seemed to work as it should, we tested both headless and non headless mode for vnc and both worked, external monitor was also live. Now, after a couple of days, without changing anything to the kit or the cables that were used to connect it to the host and the external display, we get two major issues. Firstly, the external display says “No DP signal from your device” although it worked before. Secondly, when trying to connect with headless mode to bypass the display problem, this also does not seem to work. Xrandr in headless outputs: Can’t open display instead of the appropriate output stated here: VNC (nvidia.com).
Your support on why the external monitor does not connect (although it did before) and why headless mode fails will be greatly appreciated.
Thank you!
Dear @ntsourveloudis,
Could you check if the below steps on your target and confirm if it works
On First ssh terminal
sudo service gdm3 stop
sudo service gdm stop
sudo -b X -ac -noreset
export DISPLAY=:0
sudo xrandr --fb 1920x1080 #may fail
sudo x11vnc -geometry 1920x1080 -display :0 &
Open VNC connection using VNC viewer. I would expect to see blank screen on VNC connection.
Now, open second ssh terminal launch any application which has GUI to see if it opens in VNC terminal.
Dear @SivaRamaKrishnaNV ,
Thank you for your quick reply!
The display problem was fixed by reinstalling gdm.service. The steps that you provided for the headless-mode worked.
Could you confirm if the provided steps are sufficient fix fixing the issue. Let me know if you have performed any extra steps.
As I stated in my previous post, I confirm that the provided steps worked.
Thank you!
