Isaac Sim Version
4.5.0
Operating System
Ubuntu 20.04
GPU Information
- Model: NVIDIA RTX A5000
- Driver Version: 535.230.02
Topic Description
I am running a python script inside a docker container deployed according to NVIDIA guidelines, using the ./python.sh as recommended.
Running a python script with headless set to True produces a simulation that hangs forever and breaks my docker container (I need to stop it and restart it everytime).
Specifically:
from isaacsim import SimulationApp
simulation_app = SimulationApp({"headless": True})
from isaacsim.core.api import World
my_world = World(stage_units_in_meters=1.0, backend="torch", device="cuda")
my_world.reset(soft=False)
simulation_app.update()
simulation_app.close()
hangs forever with output:
[25.922s] Simulation App Startup Complete
[25.983s] [ext: omni.physx.fabric-106.5.7] startup
[27.763s] Simulation App Shutting Down
X connection to :27 broken (explicit kill or server shutdown).
Afterwards, when trying to run any other script the simulation app hangs forever during the start-up and I need to restart the docker container to be able to use IsaacSim again.
The workaround I have is not to call simulation_app.close() in my scripts. In this case I get a bunch of warnings like
2025-04-18 13:45:46 [24,696ms] [Warning] [omni.graph.core.plugin] Could not find category 'Replicator:Annotators' for removal
2025-04-18 13:45:46 [24,697ms] [Warning] [omni.graph.core.plugin] Could not find category 'Replicator:Annotators' for removal
2025-04-18 13:45:46 [24,697ms] [Warning] [omni.graph.core.plugin] Could not find category 'Replicator:Core' for removal
2025-04-18 13:45:46 [24,774ms] [Warning] [omni.graph.core.plugin] Could not find category 'animation' for removal
2025-04-18 13:45:46 [24,776ms] [Warning] [omni.fabric.plugin] gFabricState->gUsdStageToSimStageWithHistoryMap had 1 outstanding SimStageWithHistory(s) at shutdown
2025-04-18 13:45:46 [24,778ms] [Warning] [carb.audio.context] 1 contexts were leaked
2025-04-18 13:45:46 [24,834ms] [Warning] [carb] Recursive unloadAllPlugins() detected!
Is this intended behaviour?
UPDATE:
The same exact thing happens when running with headless=False. Same error message and same breaking to the docker container, that requires a restart to be used again. But this was expected, as NVIDIA guidelines mention that docker container apps cannot be run with headless=False.
Related Issues
The issue was reported here previously in May 2024 and it was never addressed by NVIDIA.
