Hello there,
As I was coding some MonteCarlo simulation I’m facing some troubles with heap corruption.
This is the message I get:
Unhandled exception at 0x000000018000ec51 in intCUDA.exe: 0xC0000005: Access violation reading location 0xffffffffffffffff.
Aparently I’m writing to memory I don’t own I suppose.
However this is the line that sends the error:
CUDA_SAFE_CALL(cudaMemcpy(suma, sumad, sizeof(float), cudaMemcpyDeviceToHost));
It is a write back from the device to the host.
Since this is not vital to my program I commented it out to check if this was indeed the problem!
And now I get the same error but in the next line naturally meaning that the problem was not the previous one, I suppose.
This is the line that I get the error on now:
CUDA_SAFE_CALL(cudaFree(vd));
And this is the error message it throws:
Unhandled exception at 0x000000018002a053 in intCUDA.exe: 0xC0000005: Access violation reading location 0xffffffffffffffff.
When I comment all those lines out, I get this error regarding the heap corruption:
[b][i]Windows has triggered a breakpoint in intCUDA.exe.
This may be due to a corruption of the heap, and indicates a bug in intCUDA.exe or any of the DLLs it has loaded.
The output window may have more diagnostic information[/i]
[/b]
Can somebody help me out here please? Anyone who knows what’s happening?
Btw, I’m using CUDA 2.0 64bits with Vista X64 on a GF8600M GT, however right now I’m running my code on the emulator, and I’m getting different unexpected behavior everytime I run the code or recompile it.
This is the code that’s giving me trouble. The other parts of the code seem to work well:
This file is intCUDA.h
[codebox]#include <stdio.h>
#include <stdlib.h>
#include <cuda_runtime.h>
#include <cutil.h>
#define BLOCKS 5
#define THREADS 10
#define SIZE BLOCKS*THREADS
#define DIM 5
#define random //Método a ejecutar
//#define integrar
#define debug
#define dimensional[/codebox]
And this is intCUDA.cu
[codebox]
#include “intCUDA.h”
#include “drand48.h”
#include “random.h”
#include <Math.h>
device void dDimensional(float * v, float * rd, int index)
float producto = 1;
int i = index*5;
int dim = i+DIM;
for(; i < dim; i++)
producto = producto * calculo(v[i]);
printf("index = %i, i = %i, producto = %f, v[i] = %f \n",index, i, producto, v[i]);
rd[index] = producto;
global void montecarlo(float * vd, float * sumad, float * rd)
float div = SIZE;
__shared__ float sumas;
int index = blockIdx.x*blockDim.x+threadIdx.x;
#ifndef random
if(!index)
//printf("Llenando vector con midpoints...\n\n");
vd[index] = llenarVectorMidPoint(index); //Escribiendo en memoria global
#endif
#ifdef integrar
if(!index)
//printf("Integrando...\n\n");
vd[index] = calculo(vd[index])*(__fdividef(1.0,div)); //Escribiendo en memoria global
#else
#ifndef dimensional
if(!index)
//printf("Calculando Buffon...\n\n");
vd[index] = calculoBuffon(vd[index]);
#else
if(!index)
printf("Calculando dDimensional...\n\n");
printf("index = %i \n",index);
dDimensional(vd, rd, index); //Naive implementation
#endif
#endif
#ifndef dimensional
sumas += vd[index];
#else
sumas += rd[index];
#endif
//printf("b(%i) t(%i) vd[i]:%f shared: %.6f \n",blockIdx.x,threadIdx.x,vd[index], sumas);
__syncthreads();
if(threadIdx.x == THREADS-1){
*sumad = sumas;
//printf("b(%i) t(%i) shared: %f sumad: %f\n",blockIdx.x,threadIdx.x,sumas,*sumad);
void montecarlo(float * res, float * r, float * suma, const unsigned long long int size)
//puntero al input en el device
float * vd = 0;
float * rd = 0;
//espacio en el device para el input
CUDA_SAFE_CALL(cudaMalloc((void**)&vd, size*sizeof(float)));
//Copiar el vector al vector device
#ifdef random
CUDA_SAFE_CALL(cudaMemcpy(vd, res, sizeof(float)*size, cudaMemcpyHostToDevice));
#ifdef dimensional
CUDA_SAFE_CALL(cudaMalloc((void**)&rd, sizeof®));
#endif
#endif
// puntero a suma en el device
float * sumad;
CUDA_SAFE_CALL(cudaMalloc((void**)&sumad, sizeof(float)));
//Lanzar el Kernel del cálculo
montecarlo<<<BLOCKS, THREADS>>>(vd, sumad, rd);
#ifdef dimensional
CUDA_SAFE_CALL(cudaMemcpy(r, rd, size*sizeof(float), cudaMemcpyDeviceToHost));
#else
CUDA_SAFE_CALL(cudaMemcpy(r, vd, size*sizeof(float), cudaMemcpyDeviceToHost));
#endif
//CUDA_SAFE_CALL(cudaMemcpy(suma, sumad, sizeof(float), cudaMemcpyDeviceToHost));
//Liberar memoria
//CUDA_SAFE_CALL(cudaFree(vd));
// CUDA_SAFE_CALL(cudaFree(rd));
// CUDA_SAFE_CALL(cudaFree(sumad));
int main(int argc, char * argv)
CUT_DEVICE_INIT(argc, argv);
float * res = 0;
float * r = (float *)malloc(SIZE*sizeof(float)); //puntero al resultado de MC
float * suma = (float *)malloc(sizeof(float)); //puntero a suma
unsigned int hTimer;
unsigned long long int size;
#ifdef random
#ifdef dimensional
size = DIM*SIZE;
printf("Llenando vector dimensional...\n\n");
#else
size = SIZE;
printf("Llenando vector con números pseudo aleatorios...\n\n");
#endif
res = (float *)malloc(size*sizeof(float)); //puntero al resultado de RNG
startTimer(&hTimer);
rng(res, size);
stopTimer(&hTimer);
imprimir(res,size);
#endif
montecarlo(res, r, suma, size);
stopTimer(&hTimer);
imprimir(r,SIZE, *suma);
free®;
r = 0;
free(res);
res = 0;
free(suma);
suma = 0;
CUT_EXIT(argc, argv);
return 0;
[/codebox]
This is the output:
[codebox]‘intCUDA.exe’: Loaded ‘C:\Program Files (x86)\NVIDIA Corporation\NVIDIA CUDA SDK\projects\intCUDA\x64\EmuDebug\intCUDA.exe’, Symbols loaded.
‘intCUDA.exe’: Loaded ‘C:\Windows\System32\ntdll.dll’, No symbols loaded.
‘intCUDA.exe’: Loaded ‘C:\Windows\System32\kernel32.dll’, No symbols loaded.
‘intCUDA.exe’: Loaded ‘C:\CUDA\bin\cudart.dll’, Binary was not built with debug information.
‘intCUDA.exe’: Loaded ‘C:\Windows\System32\cutil64D.dll’, No symbols loaded.
‘intCUDA.exe’: Loaded ‘C:\Windows\System32\nvcuda.dll’, Binary was not built with debug information.
‘intCUDA.exe’: Loaded ‘C:\Windows\System32\user32.dll’, No symbols loaded.
‘intCUDA.exe’: Loaded ‘C:\Windows\System32\gdi32.dll’, No symbols loaded.
‘intCUDA.exe’: Loaded ‘C:\Windows\System32\advapi32.dll’, No symbols loaded.
‘intCUDA.exe’: Loaded ‘C:\Windows\System32\rpcrt4.dll’, No symbols loaded.
‘intCUDA.exe’: Loaded ‘C:\Windows\System32\opengl32.dll’, No symbols loaded.
‘intCUDA.exe’: Loaded ‘C:\Windows\System32\msvcrt.dll’, No symbols loaded.
‘intCUDA.exe’: Loaded ‘C:\Windows\System32\glu32.dll’, No symbols loaded.
‘intCUDA.exe’: Loaded ‘C:\Windows\System32\ddraw.dll’, No symbols loaded.
‘intCUDA.exe’: Loaded ‘C:\Windows\System32\dciman32.dll’, No symbols loaded.
‘intCUDA.exe’: Loaded ‘C:\Windows\System32\setupapi.dll’, No symbols loaded.
‘intCUDA.exe’: Loaded ‘C:\Windows\System32\oleaut32.dll’, No symbols loaded.
‘intCUDA.exe’: Loaded ‘C:\Windows\System32\ole32.dll’, No symbols loaded.
‘intCUDA.exe’: Loaded ‘C:\Windows\System32\dwmapi.dll’, No symbols loaded.
‘intCUDA.exe’: Loaded ‘C:\Windows\System32\imm32.dll’, No symbols loaded.
‘intCUDA.exe’: Loaded ‘C:\Windows\System32\msctf.dll’, No symbols loaded.
‘intCUDA.exe’: Loaded ‘C:\Windows\System32\lpk.dll’, No symbols loaded.
‘intCUDA.exe’: Loaded ‘C:\Windows\System32\usp10.dll’, No symbols loaded.
‘intCUDA.exe’: Loaded ‘C:\Windows\System32\nvapi64.dll’, No symbols loaded.
‘intCUDA.exe’: Loaded ‘C:\Windows\System32\shlwapi.dll’, No symbols loaded.
‘intCUDA.exe’: Loaded ‘C:\Windows\System32\shell32.dll’, No symbols loaded.
‘intCUDA.exe’: Loaded 'C:\Windows\winsxs\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.6001.18000_none_152e7382f3bd50
c6\comctl32.dll’, No symbols loaded.
The thread ‘Win64 Thread’ (0xfdc) has exited with code 0 (0x0).
The thread ‘Win64 Thread’ (0x1614) has exited with code 0 (0x0).
The thread ‘Win64 Thread’ (0x1738) has exited with code 0 (0x0).
The thread ‘Win64 Thread’ (0x1444) has exited with code 0 (0x0).
The thread ‘Win64 Thread’ (0x1334) has exited with code 0 (0x0).
The thread ‘Win64 Thread’ (0x13e0) has exited with code 0 (0x0).
The thread ‘Win64 Thread’ (0x187c) has exited with code 0 (0x0).
The thread ‘Win64 Thread’ (0xbe0) has exited with code 0 (0x0).
The thread ‘Win64 Thread’ (0x1118) has exited with code 0 (0x0).
The thread ‘Win64 Thread’ (0x1594) has exited with code 0 (0x0).
The thread ‘Win64 Thread’ (0x1958) has exited with code 0 (0x0).
The thread ‘Win64 Thread’ (0x8dc) has exited with code 0 (0x0).
The thread ‘Win64 Thread’ (0x1254) has exited with code 0 (0x0).
The thread ‘Win64 Thread’ (0x17e0) has exited with code 0 (0x0).
The thread ‘Win64 Thread’ (0xc08) has exited with code 0 (0x0).
The thread ‘Win64 Thread’ (0x1480) has exited with code 0 (0x0).
The thread ‘Win64 Thread’ (0x1590) has exited with code 0 (0x0).
The thread ‘Win64 Thread’ (0x1290) has exited with code 0 (0x0).
The thread ‘Win64 Thread’ (0x294) has exited with code 0 (0x0).
The thread ‘Win64 Thread’ (0x1a6c) has exited with code 0 (0x0).
HEAP[intCUDA.exe]: Heap block at 0000000000162170 modified at 0000000000162248 past requested size of c8
[/codebox]
