Heat sink disassembly on developer kit
Hi I am looking to experiment with the thermal solution of the developer kit for some usage and was curious if that comes off the heat transfer plate. I saw someone post from May 2023 who was having trouble. Has anyone been able to successfully take that off? As per the thermal design document and CAD, there should be only the TIM holding the heat sink + fan assembly to the thermal transfer plate. But, wanted to check if someone has been able to remove it
Sorry for the late response.
Hi, unfortunately not. I’ve been waiting to hear back from any support so we can go ahead with the purchase. Is this something that you could point us towards?
Hi, we don’t suggest to do that on devkit as that would lose warranty.
Hi, thank you i appreciate that it voids the warranty. Our primary interest is in the possibility of changing the thermal solution on the developer kit as suggested by the thermal design guide. All the while we assume the responsibility on warranty. Hence, is this something that would be possible?
Thanks !
We don’t have guide on this.
