Hello AI World for Jetpack 6.0 DP - Pytorch 2.1.0 Installed, Torchvision Did Not Install
I tried installing pytorch/torchvision with the Pip Wheel approach you suggested. But no luck. See output:
jet@sky:~$ pip3 install numpy Downloads/torch-2.1.0-cp310-cp310-linux_aarch64.whl
Defaulting to user installation because normal site-packages is not writeable
Processing ./Downloads/torch-2.1.0-cp310-cp310-linux_aarch64.whl
Requirement already satisfied: numpy in /usr/lib/python3/dist-packages (1.21.5)
Requirement already satisfied: sympy in /usr/lib/python3/dist-packages (from torch==2.1.0) (1.9)
Requirement already satisfied: networkx in /usr/local/lib/python3.10/dist-packages (from torch==2.1.0) (3.2.1)
Requirement already satisfied: jinja2 in /usr/local/lib/python3.10/dist-packages (from torch==2.1.0) (3.1.2)
Requirement already satisfied: fsspec in /usr/local/lib/python3.10/dist-packages (from torch==2.1.0) (2023.12.2)
Requirement already satisfied: typing-extensions in /usr/local/lib/python3.10/dist-packages (from torch==2.1.0) (4.9.0)
Requirement already satisfied: filelock in /usr/local/lib/python3.10/dist-packages (from torch==2.1.0) (3.13.1)
Requirement already satisfied: MarkupSafe>=2.0 in ./.local/lib/python3.10/site-packages (from jinja2->torch==2.1.0) (2.1.3)
Installing collected packages: torch
Successfully installed torch-2.1.0
jet@sky:~$ cd
jet@sky:~$ python3
Python 3.10.12 (main, Nov 20 2023, 15:14:05) [GCC 11.4.0] on linux
Type “help”, “copyright”, “credits” or “license” for more information.
import torch
torch.cuda.is_available()
True
import torchvision
File “”, line 1, in
ModuleNotFoundError: No module named ‘torchvision’
Anything else I can try before looking into the container approach. I don’t wholly understand docker/containers, I need to read into it further. Seems like anaconda but for linux.
