Hello, I have an issue working with SPI 3-wire mode.
I want to manually control the CS (Chip Select) line using GPIO,
but I always get an error when I try to use spi.no_cs = True.
Why does this happen, and how can I fix it?
any one can help
Hi khaled178234,
Are you using the devkit or custom board for Orin NX?
Please share the full dmesg and device tree for this use case.
Which GPIO you are using?
Could you elaborate on this? Do you customize something in SPI driver?
Please also help to answer these questions.
R35 (release), REVISION: 4.1, GCID: 33958178, BOARD: t186ref, EABI: aarch64, DATE: Tue Aug 1 19:57:35 UTC 2023
It’s an quite old release. Could you also verify with the latest Jetpack 5.1.5(r35.6.2) to verify?
“When I try to use spidev, it always receives 0. Why?”
What do you mean about “receives 0”? Do you mean the MISO staying LOW?
holybro-nx@holybronx-desktop:~$ sudo ./spidev_test -D /dev/spidev0.0 -p “Test” -s 500000 -H -O -v
spi mode: 0x3
bits per word: 8
max speed: 500000 Hz (500 KHz)
TX | 54 65 73 74 __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ |Test|
RX | 00 00 00 00 __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ |…|
spi mode: 0x3
bits per word: 8
holybro-nx@holybronx-desktop:~$ sudo ./spidev_test -D /dev/spidev0.0 -p “Test” -s 500000 -H -v
spi mode: 0x1
bits per word: 8
spi mode: 0x3
bits per word: 8
holybro-nx@holybronx-desktop:~$ sudo ./spidev_test -D /dev/spidev0.0 -l -v
can’t set spi mode: Invalid argument
Aborted
holybro-nx@holybronx-desktop:~$ sudo ./spidev_test -D /dev/spidev0.1 -l -v
Aborted
holybro-nx@holybronx-desktop:~$ sudo ./spidev_test -D /dev/spidev1.0 -l -v
Aborted
holybro-nx@holybronx-desktop:~$ sudo ./spidev_test -D /dev/spidev0.0 -H -O -l -v
Aborted
holybro-nx@holybronx-desktop:~$ sudo ./spidev_test -D /dev/spidev0.0 -s 500000 -b 8 -l -v
Aborted
Thanks ~1105
Could you get a scope or logic analyzer to measure the signal from both MISO and MOSO?
spi mode: 0x3
Is SPI mode 3 your expected SPI mode?
Please also verify SPI loopback test for both SPI1 and SPI3.
I would also like to check the full dmesg and device tree in your case.
