I just installed PGI Fortran (11.10) in my Ubuntu 10.04 workstation, but I’m having trouble with the debugger.
The program in question is just a simple hello world:
program hello
include ‘mpif.h’
integer ierr, myproc
call mpi_init(ierr)
call mpi_comm_rank(MPI_COMM_WORLD, myproc, ierr)
print *, “Hello world! I’m node”, myproc
call mpi_finalize(ierr)
end
I compile it with:
pgf90 -Mmpi=mpich1 -o test -g test.f90
which gives no trouble and then I can run it OK outside the debugger:
$ mpirun -np 4 ./test
Hello world! I’m node 0
Hello world! I’m node 2
Hello world! I’m node 3
Hello world! I’m node 1
But if I try to run it with the debugger:
mpirun -np 4 -dbg=pgdbg ./test
I get the following in the Command window of the debugger, with the ERRORS at the end.
PGDBG 11.10-0 x86-64 (Workstation, 16 Process)
Copyright 1989-2000, The Portland Group, Inc. All Rights Reserved.
Copyright 2000-2011, STMicroelectronics, Inc. All Rights Reserved.
Loaded: /home/angelv/Dropbox/ProgrammingGym/PPMPI/ppmpi_f/chap03/./test
pgdbg> ignore 10
Ignore signal SIGUSR1(10)
pgdbg> break main
(1)breakpoint set at: hello line: “test.f90”@4 address: 0x407406
1
pgdbg> run -p4pg /home/angelv/Dropbox/ProgrammingGym/PPMPI/ppmpi_f/chap03/PI20788 -p4wd /home/angelv/Dropbox/ProgrammingGym/PPMPI/ppmpi_f/chap03 -mpichtv
libpthread.so.0 loaded by ld-linux-x86-64.so.2.
librt.so.1 loaded by ld-linux-x86-64.so.2.
libm.so.6 loaded by ld-linux-x86-64.so.2.
libc.so.6 loaded by ld-linux-x86-64.so.2.
Breakpoint at 0x407406, function hello, file test.f90, line 4
#4: call mpi_init(ierr)
pgdbg> libnss_files.so.2 loaded by ld-linux-x86-64.so.2.
libnss_mdns4_minimal.so.2 loaded by ld-linux-x86-64.so.2.
libnss_dns.so.2 loaded by ld-linux-x86-64.so.2.
libresolv.so.2 loaded by ld-linux-x86-64.so.2.
libnss_compat.so.2 loaded by ld-linux-x86-64.so.2.
libnsl.so.1 loaded by ld-linux-x86-64.so.2.
libnss_nis.so.2 loaded by ld-linux-x86-64.so.2.
ERROR: New Process (PID 21688, HOST carro) ATTACH FAILED.
ERROR: New Process (PID 21688, HOST carro) IGNORED.
ERROR: Cannot read value at address 0x9E7300.
ERROR: Cannot read value at address 0x9E7308.
ERROR: Cannot read value at address 0x9E7310.
ERROR: New Process (PID 0, HOST unknown) IGNORED.
ERROR: Cannot read value at address 0x9E7318.
ERROR: Cannot read value at address 0x9E7320.
ERROR: Cannot read value at address 0x9E7328.
ERROR: Cannot read value at address 0x69EA08.
ERROR: Thread Running. Ignoring cont.
ERROR: Ignoring cont.
Has anybody encountered this? Any solutions?
Thanks a lot,
Ángel de Vicente
