The pre-built deviceQuery.exe
that ships with CUDA is a console application, at least up to CUDA 11.1. You would want to run that from a command prompt. If you are running it from within an IDE, you may have to configure the IDE so it does not close the window in which it displays console app output when the app terminates. For reference, here is what is output when I run the executable delivered with CUDA 11.1 from a command prompt on my Windows system (note that the “zu bytes” appears to be a bug in the pre-built application when the format specifier %zu
is used)
C:\>"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.1\extras\demo_suite\deviceQuery.exe"
C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.1\extras\demo_suite\deviceQuery.exe Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 2 CUDA Capable device(s)
Device 0: "Quadro RTX 4000"
CUDA Driver Version / Runtime Version 11.2 / 11.1
CUDA Capability Major/Minor version number: 7.5
Total amount of global memory: 8192 MBytes (8589934592 bytes)
(36) Multiprocessors, ( 64) CUDA Cores/MP: 2304 CUDA Cores
GPU Max Clock rate: 1545 MHz (1.54 GHz)
Memory Clock rate: 6501 Mhz
Memory Bus Width: 256-bit
L2 Cache Size: 4194304 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: zu bytes
Total amount of shared memory per block: zu bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 1024
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: zu bytes
Texture alignment: zu bytes
Concurrent copy and kernel execution: Yes with 6 copy engine(s)
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
CUDA Device Driver Mode (TCC or WDDM): WDDM (Windows Display Driver Model)
Device supports Unified Addressing (UVA): Yes
Device supports Compute Preemption: Yes
Supports Cooperative Kernel Launch: Yes
Supports MultiDevice Co-op Kernel Launch: No
Device PCI Domain ID / Bus ID / location ID: 0 / 101 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
Device 1: "Quadro P2000"
CUDA Capability Major/Minor version number: 6.1
Total amount of global memory: 5120 MBytes (5368709120 bytes)
( 8) Multiprocessors, (128) CUDA Cores/MP: 1024 CUDA Cores
GPU Max Clock rate: 1481 MHz (1.48 GHz)
Memory Clock rate: 3504 Mhz
Memory Bus Width: 160-bit
L2 Cache Size: 1310720 bytes
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Concurrent copy and kernel execution: Yes with 5 copy engine(s)
Device PCI Domain ID / Bus ID / location ID: 0 / 23 / 0
Compute Mode:
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 11.2, CUDA Runtime Version = 11.1, NumDevs = 2, Device0 = Quadro RTX 4000, Device1 = Quadro P2000
Result = PASS
