I tried for days, The problem is below.
When I type the command “sudo apt install nvidia-jetpack”
The Command line show the info like:
Need to get 1,160 MB/3,697 MB of archives.
After this operation, 10.4 GB of additional disk space will be used.
Do you want to continue? [Y/n]
Get:1 https://repo.download.nvidia.cn/jetson/common r34.1/main arm64 cuda-toolkit-11-4-config-common all 11.4.167-1 [16.3 kB]
Get:2 https://repo.download.nvidia.cn/jetson/common r34.1/main arm64 graphsurgeon-tf arm64 8.4.0-1+cuda11.4 [13.3 kB]
Err:2 https://repo.download.nvidia.cn/jetson/common r34.1/main arm64 graphsurgeon-tf arm64 8.4.0-1+cuda11.4
File has unexpected size (14618 != 13312). Mirror sync in progress? [IP: 112.84.125.210 443]
Hashes of expected file:
- SHA256:3c7e2770126e7ad96b7b7ffa31a9036a501a49a624be4c0713216a8286751906
- SHA1:92cb30ea394450ef112b0f8620f1df1831eecaae [weak]
- MD5Sum:3c3020804f2037d64fdfe945a026dbc3 [weak]
- Filesize:13312 [weak]
Get:3 https://repo.download.nvidia.cn/jetson/common r34.1/main arm64 libnvinfer8 arm64 8.4.0-1+cuda11.4 [167 MB]
Err:3 https://repo.download.nvidia.cn/jetson/common r34.1/main arm64 libnvinfer8 arm64 8.4.0-1+cuda11.4
File has unexpected size (165491174 != 167151752). Mirror sync in progress? [IP: 112.84.125.210 443]
- SHA256:fc7410c58c99e01fe5e0449c2856ccf01cefb98565745d1f35f85c386f2d00c6
- SHA1:e8a68a0b9075f103cfc58c5789a72938fe53a779 [weak]
- MD5Sum:1a6fe801c40621e860c655bcbc8557d2 [weak]
- Filesize:167151752 [weak]
Get:4 https://repo.download.nvidia.cn/jetson/common r34.1/main arm64 libnvinfer-plugin8 arm64 8.4.0-1+cuda11.4 [7,873 kB]
Err:4 https://repo.download.nvidia.cn/jetson/common r34.1/main arm64 libnvinfer-plugin8 arm64 8.4.0-1+cuda11.4
File has unexpected size (7888384 != 7872834). Mirror sync in progress? [IP: 112.84.125.210 443]
- SHA256:84610d06f8bf34421eff9560055908618e981536476eeeaebe296fe828322e33
- SHA1:872f4dce1355efa01ae44fe5ff3929f0631e5d6d [weak]
- MD5Sum:9188058cb64e5ef595dc4e9aa5064d2c [weak]
- Filesize:7872834 [weak]
When check the error how to fix it in the web, There is no info can solve my problem. Someone suggest to contact the repository mirror provider?
What should i do?
