Need some help, I typed ./docker_dli_run.sh and gotten the permission and IP address to login to JupyterLab, however when I entered the IP address, it doesn’t connect me to JupyterLab. Any ideas?
I tried with Ethernet cable (192.168.xx.xx) and without Ethernet cable (153.xx) it doesnt work.
Hi @s10189727, can you ping the IP address from your PC that the container tells you to connect to? Is it possible that a firewall is blocking port 8888 on your PC?
As a test, after the container is running, can you open browser on your Jetson and connect to http://localhost:8888
Thanks for the reply, Will try the provided solution.
