Hi everyone,
I connect one imx490 with TI9702/TI971 to Orin NX, TI9702 output 1.6G/lane (total two lanes), TI9702 has enable deskew, NX CSI PORT A has set lane_polarity = “6”. V4L2-CTRL and argus_camera can not get mipi data, the trace log is:
kworker/1:4-540 [001] ....... 156.407567: rtcpu_string: tstamp:5626422348 id:0x04010000 str:"VM0 deactivating."
v4l_id-1860 [002] ....... 264.557657: tegra_channel_open: vi-output, imx490 9-001a
v4l_id-1860 [002] ....... 264.557728: tegra_channel_close: vi-output, imx490 9-001a
pipewire-media--1732 [003] ....... 264.571211: tegra_channel_open: vi-output, imx490 9-001a
pipewire-media--1333 [000] ....... 264.571216: tegra_channel_open: vi-output, imx490 9-001a
pipewire-media--1333 [000] ....... 264.571348: tegra_channel_close: vi-output, imx490 9-001a
pipewire-media--1732 [003] ....... 264.571348: tegra_channel_close: vi-output, imx490 9-001a
pipewire-media--1732 [003] ....... 264.571917: tegra_channel_open: vi-output, imx490 9-001a
pipewire-media--1333 [000] ....... 264.571931: tegra_channel_open: vi-output, imx490 9-001a
pipewire-media--1732 [003] ....... 264.572088: tegra_channel_close: vi-output, imx490 9-001a
pipewire-media--1333 [000] ....... 264.572098: tegra_channel_close: vi-output, imx490 9-001a
pipewire-1731 [002] ....... 264.572915: tegra_channel_open: vi-output, imx490 9-001a
pipewire-1332 [001] ....... 264.572929: tegra_channel_open: vi-output, imx490 9-001a
pipewire-1731 [002] ....... 264.572964: tegra_channel_close: vi-output, imx490 9-001a
pipewire-1332 [001] ....... 264.572979: tegra_channel_close: vi-output, imx490 9-001a
pipewire-1332 [001] ....... 264.573657: tegra_channel_open: vi-output, imx490 9-001a
pipewire-1731 [002] ....... 264.573667: tegra_channel_open: vi-output, imx490 9-001a
pipewire-1332 [001] ....... 264.573815: tegra_channel_close: vi-output, imx490 9-001a
pipewire-1731 [002] ....... 264.573819: tegra_channel_close: vi-output, imx490 9-001a
pipewire-1332 [001] ....... 264.573845: tegra_channel_open: vi-output, imx490 9-001a
pipewire-1731 [002] ....... 264.573851: tegra_channel_open: vi-output, imx490 9-001a
pipewire-1332 [001] ....... 264.573888: tegra_channel_close: vi-output, imx490 9-001a
pipewire-1731 [002] ....... 264.573890: tegra_channel_close: vi-output, imx490 9-001a
v4l2-ctl-1862 [001] ....... 273.257171: tegra_channel_open: vi-output, imx490 9-001a
v4l2-ctl-1862 [001] ....... 273.272149: tegra_channel_set_power: imx490 9-001a : 0x1
v4l2-ctl-1862 [001] ....... 273.272243: camera_common_s_power: status : 0x1
v4l2-ctl-1862 [001] ....... 273.573478: tegra_channel_set_power: 13e00000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-1862 [001] ....... 273.573481: csi_s_power: enable : 0x1
v4l2-ctl-1862 [001] ....... 273.574394: tegra_channel_capture_setup: vnc_id 0 W 1288 H 1864 fmt c4
vi-output, imx4-1863 [002] ....... 273.581898: vi_task_submit: class_id:48 ch:0 syncpt_id:35 syncpt_thresh:0 pid:1863 tid:1863
vi-output, imx4-1863 [002] ....... 273.581906: vi_task_submit: class_id:48 ch:0 syncpt_id:35 syncpt_thresh:0 pid:1863 tid:1863
vi-output, imx4-1863 [002] ....... 273.581907: vi_task_submit: class_id:48 ch:0 syncpt_id:35 syncpt_thresh:0 pid:1863 tid:1863
vi-output, imx4-1863 [002] ....... 273.581908: vi_task_submit: class_id:48 ch:0 syncpt_id:35 syncpt_thresh:0 pid:1863 tid:1863
v4l2-ctl-1862 [000] ....... 273.582081: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-1862 [000] ....... 273.582621: tegra_channel_set_stream: 13e00000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-1862 [000] ....... 273.582625: csi_s_stream: enable : 0x1
v4l2-ctl-1862 [000] ....... 273.583028: tegra_channel_set_stream: imx490 9-001a : 0x1
kworker/1:1-57 [001] ....... 273.622083: rtcpu_string: tstamp:9287979201 id:0x04010000 str:"VM0 activating."
kworker/1:1-57 [001] ....... 273.622086: rtcpu_vinotify_event: tstamp:9288450228 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:297219932288 data:0x799d580010000000
kworker/1:1-57 [001] ....... 273.622087: rtcpu_vinotify_event: tstamp:9288450364 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:297219938688 data:0x0000000031000001
kworker/1:1-57 [001] ....... 273.622087: rtcpu_vinotify_event: tstamp:9288450519 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:297219941728 data:0x0000000007020001
kworker/1:1-57 [001] ....... 273.622087: rtcpu_vinotify_event: tstamp:9288450652 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:297219983968 data:0x799d550010000000
kworker/1:1-57 [001] ....... 273.622087: rtcpu_vinotify_event: tstamp:9288450807 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:297219990464 data:0x0000000031000002
vi-output, imx4-1864 [003] ....... 276.186964: tegra_channel_capture_setup: vnc_id 0 W 1288 H 1864 fmt c4
vi-output, imx4-1863 [001] ....... 276.187078: vi_task_submit: class_id:48 ch:0 syncpt_id:35 syncpt_thresh:0 pid:1863 tid:1863
vi-output, imx4-1863 [001] ....... 276.187088: vi_task_submit: class_id:48 ch:0 syncpt_id:35 syncpt_thresh:0 pid:1863 tid:1863
vi-output, imx4-1863 [001] ....... 276.187089: vi_task_submit: class_id:48 ch:0 syncpt_id:35 syncpt_thresh:0 pid:1863 tid:1863
vi-output, imx4-1863 [001] ....... 276.187090: vi_task_submit: class_id:48 ch:0 syncpt_id:35 syncpt_thresh:0 pid:1863 tid:1863
kworker/1:1-57 [001] ....... 276.210138: rtcpu_vinotify_event: tstamp:9369580831 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:299825112448 data:0x799d580010000000
kworker/1:1-57 [001] ....... 276.210140: rtcpu_vinotify_event: tstamp:9369580988 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:299825118816 data:0x0000000031000001
kworker/1:1-57 [001] ....... 276.210141: rtcpu_vinotify_event: tstamp:9369581123 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:299825121824 data:0x0000000007020001
kworker/1:1-57 [001] ....... 276.210142: rtcpu_vinotify_event: tstamp:9369581275 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:299825164096 data:0x799d550010000000
kworker/1:1-57 [001] ....... 276.210142: rtcpu_vinotify_event: tstamp:9369581409 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:299825170624 data:0x0000000031000002
vi-output, imx4-1864 [003] ....... 278.747014: tegra_channel_capture_setup: vnc_id 0 W 1288 H 1864 fmt c4
vi-output, imx4-1863 [001] ....... 278.747122: vi_task_submit: class_id:48 ch:0 syncpt_id:35 syncpt_thresh:0 pid:1863 tid:1863
vi-output, imx4-1863 [001] ....... 278.747133: vi_task_submit: class_id:48 ch:0 syncpt_id:35 syncpt_thresh:0 pid:1863 tid:1863
vi-output, imx4-1863 [001] ....... 278.747135: vi_task_submit: class_id:48 ch:0 syncpt_id:35 syncpt_thresh:0 pid:1863 tid:1863
vi-output, imx4-1863 [001] ....... 278.747136: vi_task_submit: class_id:48 ch:0 syncpt_id:35 syncpt_thresh:0 pid:1863 tid:1863
kworker/1:1-57 [001] ....... 278.786194: rtcpu_vinotify_event: tstamp:9449697283 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:302385153152 data:0x799d580010000000
kworker/1:1-57 [001] ....... 278.786197: rtcpu_vinotify_event: tstamp:9449697422 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:302385159552 data:0x0000000031000001
kworker/1:1-57 [001] ....... 278.786197: rtcpu_vinotify_event: tstamp:9449697575 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:302385162560 data:0x0000000007020001
kworker/1:1-57 [001] ....... 278.786198: rtcpu_vinotify_event: tstamp:9449697720 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:302385209696 data:0x799d550010000000
kworker/1:1-57 [001] ....... 278.786199: rtcpu_vinotify_event: tstamp:9449697875 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:302385216192 data:0x0000000031000002
what does this VIFALC_TDSTATE state mean? thanks for your help.
