Hi guys,
I am doing a comparison between CUDA, MPI, OpenMP and Pthreads.
I implemented the algorithm bitonic MergeSort in Pthread, MPI and OpenMP.
I try to implement it in CUDA, but I no have sucess, because device and global methods in CUDA have restrictions ( per example memcpy function in device and the limit of 16KB per block of threads)
Can you help me?
Thank you in advance.
Bellow the algorithm in Pthreads and more bellow in CUDA
Pthreads
[codebox]#include <stdio.h>
#include <stdlib.h>
#include <pthread.h> /* pthreads */
#include <sys/time.h> /* tempo de execução */
#include <string.h> /* memcpy */
/*#define LARGURA 524288 //2^19
#define ELEMENTOS 131072
#define LARGURA 262144 //2^18
#define ELEMENTOS 65536
#define LARGURA 131072 //2^17
#define ELEMENTOS 32768
#define LARGURA 65536 //2^16
#define ELEMENTOS 16384
#define LARGURA 32768 //2^15
#define ELEMENTOS 8192
#define LARGURA 16384 //2^14
#define ELEMENTOS 4096
#define LARGURA 8192 //2^13
#define ELEMENTOS 2048
#define LARGURA 4096 //2^12
#define ELEMENTOS 1024
#define LARGURA 2048 //2^11
#define ELEMENTOS 512
#define LARGURA 1024 //2^10
#define ELEMENTOS 256
// Tamanho para teste simples
#define LARGURA 8
#define ELEMENTOS 2
// Debug
#define DEBUG 0
int vetor[LARGURA];
pthread_barrier_t barrier;
// Adicionado QuickSort iterativo, versão do professor Paulo Feofiloff
void quickSort_it (int v, int p, int r)
int j, *pilhap, *pilhar, t;
pilhap = malloc ((r-p+1) * sizeof (int));
pilhar = malloc ((r-p+1) * sizeof (int));
pilhap[0] = p;
pilhar[0] = r;
t = 0;
while (t >= 0)
p = pilhap[t];
r = pilhar[t];
t--;
if (p < r)
j = separa (v, p, r);
t++;
pilhap[t] = p;
pilhar[t] = j-1;
t++;
pilhap[t] = j+1;
pilhar[t] = r;
// Adicionado separa versão do professor Paulo Feofiloff
int separa (int v, int p, int r)
int c = v[p], i = p+1, j = r, t;
while ( i <= j)
if (v[i] <= c) ++i;
else if (c < v[j]) --j;
else
t = v[i], v[i] = v[j], v[j] = t;
++i; --j;
v[p] = v[j], v[j] = c;
return j;
void carregaVetor()
FILE *arquivo;
int i=0, num;
arquivo = fopen("randomicos.txt", "r");
for(i=0; i < LARGURA; i++)
fscanf (arquivo, "%d", &num);
vetor[i] = num;
fclose(arquivo);
void imprimeVetor(){
int i;
for(i=0; i < LARGURA; i++){
printf("%d\n", vetor[i]);
void *bitonicMergesort(void *args)
int i, j, k, l, numprocs, myid, aux;
numprocs = (LARGURA / ELEMENTOS);
myid = (int)args;
int vetorLocal[ELEMENTOS * 2];
quickSort_it(vetor, (myid * ELEMENTOS), (myid * ELEMENTOS) + ELEMENTOS -1);
//DESORDENADO - FASE 1
for (k = 1; k < numprocs / 2; k = k * 2)
{//Controle da fase
if ((myid % (k * 4)) < (k * 2))
{//ORDENA CRESCENTE
if (myid % (k * 2) < k)
{ //Processa
memcpy(vetorLocal,&vetor[myid * ELEMENTOS],sizeof(int) * ELEMENTOS);
memcpy(&vetorLocal[ELEMENTOS],&vetor[(myid + k) * ELEMENTOS], sizeof(int) * ELEMENTOS);
quickSort_it(vetorLocal, 0,(ELEMENTOS *2)-1);
memcpy(&vetor[myid * ELEMENTOS],vetorLocal ,sizeof(int) * ELEMENTOS);
memcpy(&vetor[(myid + k) * ELEMENTOS], &vetorLocal[ELEMENTOS], sizeof(int) * ELEMENTOS);
else
{ //ORDENA DECRESCENTE
{ //Processa
memcpy(&vetor[(myid + k) * ELEMENTOS],vetorLocal ,sizeof(int) * ELEMENTOS);
memcpy(&vetor[myid * ELEMENTOS], &vetorLocal[ELEMENTOS], sizeof(int) * ELEMENTOS);
pthread_barrier_wait(&barrier);
if (k > 1)
{ //Acerta os Valores
for (l = k / 2; l >= 1; l = l / 2)
if (myid % (k * 4) < (k * 2))
{ //Crescente
if (myid % (l * 2) < l)
{ //Processa
memcpy(&vetorLocal[ELEMENTOS], &vetor[(myid + k) * ELEMENTOS], sizeof(int) * ELEMENTOS);
quickSort_it(vetorLocal, 0, (ELEMENTOS * 2) -1);
else{ //Decrescente
{ //Processa
//FASE 2 - Bitonico
for (k = numprocs/2; k >= 1; k = k / 2)
{ //Controle da fase
{ //Processa
void escreveTempos(double tempo[5]){
FILE *arquivo;
int i;
arquivo = fopen("temposPthreads.txt", "a+");
for(i=0; i < 5; i++)
fprintf(arquivo, "-> %d itens: %lf s\n",LARGURA, tempo[i]);
fclose(arquivo);
int main ()
double diferenca[5];
struct timeval tvAntes, tvDepois;
int i,j;
for (j=0; j < 5; j++)
carregaVetor();
pthread_t threads[(LARGURA / ELEMENTOS)];
pthread_barrier_init(&barrier, NULL,(LARGURA / ELEMENTOS));
if(gettimeofday(&tvAntes,NULL)<0)
perror("gettimeofday");
for (i = 0; i < (LARGURA / ELEMENTOS); i++)
pthread_create(&threads[i], NULL, bitonicMergesort, (int *)i);
pthread_join(threads[i], NULL);
if(gettimeofday(&tvDepois,NULL)<0)
diferenca[j] = (((double)tvDepois.tv_sec) - ((double)tvAntes.tv_sec)) + ((((double)tvDepois.tv_usec) - ((double)tvAntes.tv_usec)) / 1000000);
escreveTempos(diferenca);
#if DEBUG == 1
imprimeVetor();
#endif
return 0;
[/codebox]
My CUDA implementation
[codebox]
#ifndef BITONIC_KERNEL_CU
#define BITONIC_KERNEL_CU
// Tamanho dos vetores utilizados nos testes
#define ELEMENTOS 512 */
//#define LARGURA 512//2^10
//#define ELEMENTOS 128
//#define LARGURA 256//2^10
//#define ELEMENTOS 64
//#define LARGURA 8 //2^10
//#define ELEMENTOS 2
#define LARGURA 128 //2^10
- Método separa do quicksort
device static int separa (int v, int p, int r)
while (i <= j)
if (v[i] <= c) ++i;
else {
++i; --j;
return j;
Algoritmo quicksort iterativo
Será executado pela GPU
device static void quickSort_it(int v, int p, int r)
int j, t;
extern __shared__ int pilhap[];
extern __shared__ int pilhar[];
pilhap[0] = p;
pilhar[0] = r;
t = 0;
while (t >= 0) {
p = pilhap[t];
r = pilhar[t];
t--;
if (p < r) {
j = separa(v, p, r);
t++;
pilhap[t] = p;
pilhar[t] = j - 1;
t++;
pilhap[t] = j + 1;
pilhar[t] = r;
pilhap[0] = p;
pilhar[0] = r;
t = 0;
while (t >= 0) {
p = pilhap[t];
r = pilhar[t];
t--;
while (p < r) {
t++;
pilhap[t] = p;
pilhar[t] = j - 1;
p = j + 1;
Bitonic MergeSort
Será chamado pela CPU, mas executado na GPU
global static void bitonicMergeSort(int * vetor)
const unsigned int myid = threadIdx.x;
unsigned int k, l, numprocs;
unsigned int vetorLocal[ELEMENTOS * 2];
extern __shared__ int vetorLocal[];
quickSort_it(vetor, (myid * ELEMENTOS), (myid * ELEMENTOS) + ELEMENTOS - 1);
//Controle da fase
//ORDENA CRESCENTE
//Processa
memcpy(vetorLocal, &vetor[myid * ELEMENTOS], sizeof(int) * ELEMENTOS);
memcpy(&vetorLocal[ELEMENTOS], &vetor[(myid + k) * ELEMENTOS],sizeof(int) * ELEMENTOS);
quickSort_it(vetorLocal, 0, (ELEMENTOS * 2) - 1);
memcpy(&vetor[myid * ELEMENTOS], vetorLocal, sizeof(int) * ELEMENTOS);
} else
//Processa
memcpy(&vetor[(myid + k) * ELEMENTOS], vetorLocal, sizeof(int) * ELEMENTOS);
__syncthreads();
if (k > 1)
//Acerta os Valores
//Crescente
//Processa
} else {
//Decrescente
if (myid % (l * 2) < l) {
//Processa
__syncthreads();
// __syncthreads();
__syncthreads();
//FASE 2 - Bitonico
for (k = numprocs / 2; k >= 1; k = k / 2) {
//Controle da fase
//Processa
quickSort_it(vetor, 0, (ELEMENTOS * 2) - 1);
__syncthreads();
#endif // BITONIC_KERNEL_H[/codebox]
