Two small SMD components were accidentally knocked off my Jetson Orin Nano 4GB module. Could anyone help identify the correct replacement parts?
Module: Jetson Orin Nano 4GB
PCB marking: 180-13767-DAAA-A23
The missing components are in the area circled in red in the attached photo, on the back of the module, below the CE marking.
They may be ceramic capacitors, but I have not confirmed this. Could anyone provide:
- The component type and reference designators.
- The capacitance, voltage rating, and package size, if they are capacitors.
- A clear close-up photo of the same area on an intact 4GB module with the same PCB revision.
I understand that the module schematic and BOM are not publicly available. Any information from someone with a matching board or repair experience would be greatly appreciated.
Thank you!
