I rollback to this pipeline:
gst-launch-1.0 -v v4l2src device=/dev/video1 ! image/jpeg,width=1280,height=720, framerate=60/1! jpegparse ! jpegdec ! nvvidconv ! nvv4l2h265enc insert-sps-pps=1 insert-vui=1 ! h265parse ! video/x-h265,stream-format=byte-stream,alignment=au ! rtph265pay mtu=1400 config-interval=1 ! udpsink host=X.X.X.X port=5000
Setting pipeline to PAUSED ...
Opening in BLOCKING MODE
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = image/jpeg, width=(int)1280, height=(int)720, framerate=(fraction)60/1, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)NULL, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = image/jpeg, width=(int)1280, height=(int)720, framerate=(fraction)60/1, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)NULL, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstJpegParse:jpegparse0.GstPad:sink: caps = image/jpeg, width=(int)1280, height=(int)720, framerate=(fraction)60/1, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)NULL, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = image/jpeg, width=(int)1280, height=(int)720, framerate=(fraction)60/1, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string)NULL, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstJpegParse:jpegparse0.GstPad:src: caps = image/jpeg, parsed=(boolean)true, format=(string)UYVY, width=(int)1280, height=(int)720, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstJpegDec:jpegdec0.GstPad:sink: caps = image/jpeg, parsed=(boolean)true, format=(string)UYVY, width=(int)1280, height=(int)720, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstJpegDec:jpegdec0.GstPad:src: caps = video/x-raw, format=(string)I420, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)1:4:0:0, framerate=(fraction)60/1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)60/1, pixel-aspect-ratio=(fraction)1/1, format=(string)I420, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono
/GstPipeline:pipeline0/nvv4l2h265enc:nvv4l2h265enc0.GstPad:src: caps = video/x-h265, stream-format=(string)byte-stream, alignment=(string)au, profile=(string)NULL, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)60/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono
/GstPipeline:pipeline0/GstH265Parse:h265parse0.GstPad:sink: caps = video/x-h265, stream-format=(string)byte-stream, alignment=(string)au, profile=(string)NULL, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)60/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono
NvMMLiteOpen : Block : BlockType = 8
Redistribute latency...
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 8
/GstPipeline:pipeline0/nvv4l2h265enc:nvv4l2h265enc0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)60/1, pixel-aspect-ratio=(fraction)1/1, format=(string)I420, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw, format=(string)I420, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)1:4:0:0, framerate=(fraction)60/1
NVMEDIA: H265 : Profile : 1
/GstPipeline:pipeline0/GstH265Parse:h265parse0.GstPad:src: caps = video/x-h265, stream-format=(string)byte-stream, alignment=(string)au, profile=(string)main, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)60/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, tier=(string)main, level=(string)4
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-h265, stream-format=(string)byte-stream, alignment=(string)au, profile=(string)main, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)60/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, tier=(string)main, level=(string)4
/GstPipeline:pipeline0/GstRtpH265Pay:rtph265pay0.GstPad:sink: caps = video/x-h265, stream-format=(string)byte-stream, alignment=(string)au, profile=(string)main, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)60/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, tier=(string)main, level=(string)4
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-h265, stream-format=(string)byte-stream, alignment=(string)au, profile=(string)main, width=(int)1280, height=(int)720, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)60/1, interlace-mode=(string)progressive, colorimetry=(string)bt709, chroma-site=(string)mpeg2, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, tier=(string)main, level=(string)4
/GstPipeline:pipeline0/GstRtpH265Pay:rtph265pay0.GstPad:src: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, ssrc=(uint)2781487109, timestamp-offset=(uint)1009096371, seqnum-offset=(uint)21853, a-framerate=(string)60
/GstPipeline:pipeline0/GstUDPSink:udpsink0.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H265, ssrc=(uint)2781487109, timestamp-offset=(uint)1009096371, seqnum-offset=(uint)21853, a-framerate=(string)60
/GstPipeline:pipeline0/GstRtpH265Pay:rtph265pay0.GstPad:src: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H265, sprop-vps=(string)QAEMAf//AUAAAAMAAAMAAAMAAAMAeKwJ, sprop-sps=(string)"QgEBAUAAAAMAAAMAAAMAAAMAeKACgIAuHxOWtKQhGS4moAAAoIAAAAMAgAAAHgQ\=", sprop-pps=(string)"RAHA88DMkA\=\=", payload=(int)96, seqnum-offset=(uint)21853, timestamp-offset=(uint)1009096371, ssrc=(uint)2781487109, a-framerate=(string)60
/GstPipeline:pipeline0/GstUDPSink:udpsink0.GstPad:sink: caps = application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H265, sprop-vps=(string)QAEMAf//AUAAAAMAAAMAAAMAAAMAeKwJ, sprop-sps=(string)"QgEBAUAAAAMAAAMAAAMAAAMAeKACgIAuHxOWtKQhGS4moAAAoIAAAAMAgAAAHgQ\=", sprop-pps=(string)"RAHA88DMkA\=\=", payload=(int)96, seqnum-offset=(uint)21853, timestamp-offset=(uint)1009096371, ssrc=(uint)2781487109, a-framerate=(string)60
/GstPipeline:pipeline0/GstRtpH265Pay:rtph265pay0: timestamp = 1009168579
/GstPipeline:pipeline0/GstRtpH265Pay:rtph265pay0: seqnum = 21853
^Chandling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 0:00:13.592114624
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
The Receiver is getting:
gst-launch-1.0 udpsrc port=5000 ! application/x-rtp,encoding-name=H265,payload=96 ! rtph265depay ! video/x-h265,stream-format=byte-stream,alignment=au ! decodebin ! autovideosink -ev
/viewer_camera1.sh
Got context from element 'autovideosink0': gst.gl.GLDisplay=context, gst.gl.GLDisplay=(GstGLDisplay)"\(GstGLDisplayX11\)\ gldisplayx11-0";
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = application/x-rtp, encoding-name=(string)H265, payload=(int)96, media=(string)video, clock-rate=(int)90000
/GstPipeline:pipeline0/GstRtpH265Depay:rtph265depay0.GstPad:src: caps = video/x-h265, stream-format=(string)byte-stream, alignment=(string)au
/GstPipeline:pipeline0/GstDecodeBin:decodebin0.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-h265, stream-format=(string)byte-stream, alignment=(string)au
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstTypeFindElement:typefind.GstPad:src: caps = video/x-h265, stream-format=(string)byte-stream, alignment=(string)au
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstH265Parse:h265parse0.GstPad:sink: caps = video/x-h265, stream-format=(string)byte-stream, alignment=(string)au
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstTypeFindElement:typefind.GstPad:sink: caps = video/x-h265, stream-format=(string)byte-stream, alignment=(string)au
/GstPipeline:pipeline0/GstDecodeBin:decodebin0.GstGhostPad:sink: caps = video/x-h265, stream-format=(string)byte-stream, alignment=(string)au
/GstPipeline:pipeline0/GstRtpH265Depay:rtph265depay0.GstPad:sink: caps = application/x-rtp, encoding-name=(string)H265, payload=(int)96, media=(string)video, clock-rate=(int)90000
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstH265Parse:h265parse0.GstPad:src: caps = video/x-h265, stream-format=(string)byte-stream, alignment=(string)au, width=(int)1280, height=(int)720, framerate=(fraction)60/1, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, profile=(string)main, tier=(string)main, level=(string)4
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/avdec_h265:avdec_h265-0.GstPad:sink: caps = video/x-h265, stream-format=(string)byte-stream, alignment=(string)au, width=(int)1280, height=(int)720, framerate=(fraction)60/1, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, profile=(string)main, tier=(string)main, level=(string)4
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter2.GstPad:src: caps = video/x-h265, stream-format=(string)byte-stream, alignment=(string)au, width=(int)1280, height=(int)720, framerate=(fraction)60/1, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, profile=(string)main, tier=(string)main, level=(string)4
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter2.GstPad:sink: caps = video/x-h265, stream-format=(string)byte-stream, alignment=(string)au, width=(int)1280, height=(int)720, framerate=(fraction)60/1, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, profile=(string)main, tier=(string)main, level=(string)4
/GstPipeline:pipeline0/GstDecodeBin:decodebin0/avdec_h265:avdec_h265-0.GstPad:src: caps = video/x-raw, format=(string)I420, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)2:4:5:1, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0.GstGhostPad:sink.GstProxyPad:proxypad1: caps = video/x-raw, format=(string)I420, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)2:4:5:1, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0/GstGLImageSinkBin:autovideosink0-actual-sink-glimage.GstGhostPad:sink.GstProxyPad:proxypad2: caps = video/x-raw, format=(string)I420, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)2:4:5:1, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0/GstGLImageSinkBin:autovideosink0-actual-sink-glimage/GstGLUploadElement:gluploadelement0.GstPad:src: caps = video/x-raw(memory:GLMemory), format=(string)I420, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)2:4:5:1, framerate=(fraction)60/1, texture-target=(string)2D
/GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0/GstGLImageSinkBin:autovideosink0-actual-sink-glimage/GstGLColorConvertElement:glcolorconvertelement0.GstPad:src: caps = video/x-raw(memory:GLMemory), format=(string)RGBA, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)60/1, texture-target=(string)2D
/GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0/GstGLImageSinkBin:autovideosink0-actual-sink-glimage/GstGLColorBalance:glcolorbalance0.GstPad:src: caps = video/x-raw(memory:GLMemory), format=(string)RGBA, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)60/1, texture-target=(string)2D
/GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0/GstGLImageSinkBin:autovideosink0-actual-sink-glimage/GstGLImageSink:sink.GstPad:sink: caps = video/x-raw(memory:GLMemory), format=(string)RGBA, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)60/1, texture-target=(string)2D
/GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0/GstGLImageSinkBin:autovideosink0-actual-sink-glimage/GstGLColorBalance:glcolorbalance0.GstPad:sink: caps = video/x-raw(memory:GLMemory), format=(string)RGBA, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)60/1, texture-target=(string)2D
/GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0/GstGLImageSinkBin:autovideosink0-actual-sink-glimage/GstGLColorConvertElement:glcolorconvertelement0.GstPad:sink: caps = video/x-raw(memory:GLMemory), format=(string)I420, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)2:4:5:1, framerate=(fraction)60/1, texture-target=(string)2D
/GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0/GstGLImageSinkBin:autovideosink0-actual-sink-glimage/GstGLUploadElement:gluploadelement0.GstPad:sink: caps = video/x-raw, format=(string)I420, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)2:4:5:1, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0/GstGLImageSinkBin:autovideosink0-actual-sink-glimage.GstGhostPad:sink: caps = video/x-raw, format=(string)I420, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)2:4:5:1, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0.GstGhostPad:sink: caps = video/x-raw, format=(string)I420, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)2:4:5:1, framerate=(fraction)60/1
/GstPipeline:pipeline0/GstDecodeBin:decodebin0.GstDecodePad:src_0.GstProxyPad:proxypad3: caps = video/x-raw, format=(string)I420, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, chroma-site=(string)mpeg2, colorimetry=(string)2:4:5:1, framerate=(fraction)60/1
WARNING: from element /GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0/GstGLImageSinkBin:autovideosink0-actual-sink-glimage/GstGLImageSink:sink: A lot of buffers are being dropped.
Additional debug info:
gstbasesink.c(2902): gst_base_sink_is_too_late (): /GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0/GstGLImageSinkBin:autovideosink0-actual-sink-glimage/GstGLImageSink:sink:
There may be a timestamping problem, or this computer is too slow.
EOS on shutdown enabled -- Forcing EOS on the pipeline
Waiting for EOS...
Got EOS from element "pipeline0".
EOS received - stopping pipeline...
Execution ended after 0:12:15.203933644
double free or corruption (out)
./viewer_camera1.sh: line 1: 21723 Aborted (core dumped) gst-launch-1.0 udpsrc port=5000 ! application/x-rtp,encoding-name=H265,payload=96 ! rtph265depay ! video/x-h265,stream-format=byte-stream,alignment=au ! decodebin ! autovideosink -ev
The USB3 Camera support the following resolution outputs:
v4l2-ctl -d /dev/video0 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: ‘UYVY’
Interval: Discrete 0.062s (16.000 fps)
Interval: Discrete 0.125s (8.000 fps)
Size: Discrete 1920x1080
Interval: Discrete 0.250s (4.000 fps)
Size: Discrete 3840x2160
Interval: Discrete 0.500s (2.000 fps)
Size: Discrete 4208x3120
Interval: Discrete 1.000s (1.000 fps)
Size: Discrete 4096x2160
Interval: Discrete 0.017s (60.000 fps)
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.083s (12.000 fps)
Interval: Discrete 0.167s (6.000 fps)
Size: Discrete 1920x1440
Interval: Discrete 0.333s (3.000 fps)
Size: Discrete 2880x2160
Index : 1
Pixel Format: 'MJPG' (compressed)
Interval: Discrete 0.050s (20.000 fps)
Interval: Discrete 0.008s (120.000 fps)
I believe MJPEG is the preferred right?
