When I issue this command, however:
/opt/ove/base_stack# docker compose --env-file /opt/ove/base_stack/nucleus-stack.env -f /opt/ove/base_stack/nucleus-stack-no-ssl.yml pull
I get this response:
unable to get image ‘nvcr.io/nvidia/omniverse/nucleus-auth:1.5.8’: Error response from daemon: client version 1.53 is too new. Maximum supported API version is 1.41
Next steps? I’m unclear where to start looking; this isn’t covered in the documentation. Thanks.
Thanks everyone for the info. We are discussing this issue with the software distribution team and will report back once we have additional information.
In the interim, using the export command @spencer7 mentioned in the thread is the correct workaround.
