help! kernel compile status as warning
[font=“Courier”]I compile the kernel as down and it return :
warning:latest line of file ends without a newline
#endif
kernel
#ifndef __GEN_PARTICLES_KERNEL__
#define __GEN_PARTICLES_KERNEL__
#define IMAD(X,Y,Z) (__mul24(X,Y)+Z)
#define IMUL(X,Y) __mul24(X,Y)
__global__
void GenParticles_kernel(float3* oPos,float4* oCol,float scale)
    unsigned int tidx=IMAD(blockIdx.x,blockDim.x,threadIdx.x);
    unsigned int tidy=IMAD(blockIdx.y,blockDim.y,threadIdx.y);
    unsigned int tidz=IMAD(blockIdx.z,blockDim.z,threadIdx.z);
    unsigned int threadsPerCol=IMUL(blockDim.x,gridDim.x);
    unsigned int threadsPerRow=IMUL(blockDim.y,gridDim.y);
    unsigned int oid=IMUL(IMAD(tidz,threadsPerRow,tidy),threadsPerCol)+tidx;
   float sPosX=(float)tidx;
    float sPosY=(float)tidy;
    sPosX*=scale;
    sPosY*=scale;
    oPos[oid].x=sPosX;
    oPos[oid].y=sPosY;
    oPos[oid].z=scale*gridDim.y;
   __syncthreads();
#endif
but when changed to this ,it as good:
//device code for generate cube mesh particles
texture<float4,2,cudaReadModeElementType> f4tex;
__global__
   //global index for per-particles
    //z*witdh*height+y*width+x
    //caculate texcoords
    float u=tidx/(float)threadsPerCol;
    float v=tidy/(float)threadsPerRow;
    u+=0.5F;
    v+=0.5F;
    //compute out pos of per particle with per thread
    sPosX*=scale;
    sPosY*=scale;
   oPos[oid].x=sPosX;
    oPos[oid].y=sPosY;
    oPos[oid].z=scale*gridDim.y;//gridDim.y determinates the z-offset of per layer point mesh
    oCol[oid]=tex2D(f4tex,u,v);
    __syncthreads();
#endif
And this kernel is in same case:
#ifndef __UPDATE_PARTICLES_KERNEL__
#define __UPDATE_PARTICLES_KERNEL__
#define __UPDATE_COLOR__
__global__ void transferParticles_kernel(
float3* newPos,
float3* oldPos,
#ifdef __UPDATE_COLOR__
float4* newCol,
float4* oldCol,
float scaleR,float scaleG,float scaleB,float scaleA,
#endif
float dt,
float forceX,float forceY,float forceZ,
float attenCoeffXA,float attenCoeffXB,float attenCoeffXC,
float attenCoeffYA,float attenCoeffYB,float attenCoeffYC,
float attenCoeffZA,float attenCoeffZB,float attenCoeffZC)
   float attenuationX=1.0F/(dt*(dt*attenCoeffXA+attenCoeffXB)+attenCoeffXC);
    float attenuationY=1.0F/(dt*(dt*attenCoeffYA+attenCoeffYB)+attenCoeffYC);
    float attenuationZ=1.0F/(dt*(dt*attenCoeffZA+attenCoeffZB)+attenCoeffZC);
#ifdef __UPDATE__COLOR__
    newCol[oid].x=scaleR*oldCol[oid].x;
    newCol[oid].y=scaleG*oldCol[oid].y;
    newCol[oid].z=scaleB*oldCol[oid].z;
    newCol[oid].w=scaleA*oldCol[oid].w;
#endif
   newPos[oid].x=attenuationX*sinf(dt)*cosf(dt/2.0F)*forceX*oldPos[oid].x;
    newPos[oid].y=attenuationY*sinf(dt)*cosf(dt/2.0F)*forceY*oldPos[oid].y;
    newPos[oid].z=attenuationZ*cosf(dt)*forceZ*oldPos[oid].z;
   __syncthreads();
#endif
why?
[/font]
