Hello, I built and run TRT V6 engine successfully from Pytorch using TRT Python APIs as below.
The target model is “Resnet-26-D” which is a recently improved official model from “timm” pytorch library.
You can just copy and paste to reproduce my case.
import random
from PIL import Image
import tensorrt as trt
import pycuda.driver as cuda
import pycuda.autoinit
import model
import sys, os
sys.path.insert(1, os.path.join(sys.path[0], ".."))
import common
import numpy as np
import timm
import torch
import time
TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
class ModelData(object):
INPUT_NAME = "data"
INPUT_SHAPE = (3, 224, 224)
OUTPUT_NAME = "prob"
OUTPUT_SIZE = 1000
DTYPE = trt.float32
MODEL_PATH = "ResNet50_fp32.caffemodel" #just dummmy
DEPLOY_PATH = "ResNet50_N2.prototxt" #just dummmy
def layer_conv(network, input=None, weight=None, output_size=32, kernel_size=(3, 3), stride=(1, 1), padding=(1, 1), padding_mode=None):
conv = network.add_convolution(input,
num_output_maps=output_size,
kernel_shape=kernel_size,
kernel=weight,
bias=np.zeros(output_size).astype(np.float32))
conv.stride = stride
#if padding_mode != None:
# conv.padding_mode = padding_mode
#print(padding_mode)
conv.padding = padding
#conv.pre_padding = padding
#conv.post_padding = padding
DEFAULT : # 112 55 27/28
EXPLICIT_ROUND_DOWN : Use explicit padding, rounding the output size down
EXPLICIT_ROUND_UP : Use explicit padding, rounding the output size up # 113 56 28/29
SAME_UPPER : Use SAME padding, with pre_padding <= post_padding
SAME_LOWER : Use SAME padding, with pre_padding >= post_padding
CAFFE_ROUND_DOWN : Use CAFFE padding, rounding the output size down
CAFFE_ROUND_UP : Use CAFFE padding, rounding the output size up
return conv
def layer_bn(network, input, g0, b0, m0, v0 ):
adjustedScale = scale / sqrt(variance + epsilon)
batchNorm = (input + bias - (adjustedScale * mean)) * adjustedScale
#g0 = params['batchnorm0_gamma'].asnumpy().reshape(-1)
#b0 = params['batchnorm0_beta'].asnumpy().reshape(-1)
#m0 = extra_params['batchnorm0_moving_mean'].asnumpy().reshape(-1)
#v0 = extra_params['batchnorm0_moving_var'].asnumpy().reshape(-1)
scale0 = g0 / np.sqrt(v0 + 2e-5)
shift0 = -m0 / np.sqrt(v0 + 2e-5) * g0 + b0
power0 = np.ones(len(g0), dtype=np.float32)
batchNormLayer = network.add_scale(input, trt.ScaleMode.CHANNEL,
trt.Weights(shift0), trt.Weights(scale0), trt.Weights(power0))
return batchNormLayer
def build_block(network, input, layer_list, weights, weight_list, bn_param_list, output_size_list,
kernel_size_list, stride_list, avgpool_kernel_size=0, avgpool_stride_size=0, padding_mode=None):
output = input
conv_count=0
bn_count =0
for l in layer_list:
if l == 'Conv2d':
#output_layer = network.add_padding(input=output,
# pre_padding=(int(kernel_size_list[conv_count]/2), int(kernel_size_list[conv_count]/2)),
# post_padding=((int(kernel_size_list[conv_count]/2), int(kernel_size_list[conv_count]/2))))
#_layer.get_output(0)
output_layer = layer_conv(network, output,
weight=weights[weight_list[conv_count]].numpy(),
output_size=output_size_list[conv_count],
kernel_size=(kernel_size_list[conv_count], kernel_size_list[conv_count]),
stride=(stride_list[conv_count], stride_list[conv_count]),
padding= (int(kernel_size_list[conv_count]/2), int(kernel_size_list[conv_count]/2)),
padding_mode=padding_mode)
conv_count+=1
print('AFTER CONVOLUTION')
print('output_tensor shape: ', output_layer.get_output(0).shape) # output_layer.get_output(0).shape[1])
print('kernel :', (kernel_size_list[conv_count - 1], kernel_size_list[conv_count - 1]), 'padding : ',
(int(kernel_size_list[conv_count - 1] / 2), int(kernel_size_list[conv_count - 1] / 2)), 'stride: ',
(stride_list[conv_count - 1], stride_list[conv_count - 1]))
elif l == 'BatchNorm2d':
g=weights[bn_param_list[bn_count][0]].numpy()
b=weights[bn_param_list[bn_count][1]].numpy()
m=weights[bn_param_list[bn_count][2]].numpy()
v=weights[bn_param_list[bn_count][3]].numpy()
output_layer = layer_bn(network, output, g, b, m, v)
bn_count += 1
elif l == 'Relu':
output_layer = network.add_activation(input=output, type=trt.ActivationType.RELU)
elif l == 'AvgPool2d':
output_layer = network.add_pooling(output, trt.PoolingType.AVERAGE, (avgpool_kernel_size, avgpool_kernel_size))
output_layer.stride = (avgpool_stride_size, avgpool_stride_size)
output_layer.padding = (0, 0)
print('AFTER AVG POOL')
output = output_layer.get_output(0)
print('')
return output
def build_layer(network,weights, input_layer, layer_number, output_size_lists, stride_size_lists, padding_mode):
(0): Bottleneck(
# block1_0
(conv1): Conv2d(64, 64, kernel_size=(1, 1), stride=(1, 1), bias=False)
(bn1): BatchNorm2d(64, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
(conv2): Conv2d(64, 64, kernel_size=(3, 3), stride=(1, 1), padding=(1, 1), bias=False)
(bn2): BatchNorm2d(64, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
(conv3): Conv2d(64, 256, kernel_size=(1, 1), stride=(1, 1), bias=False) 6
(bn3): BatchNorm2d(256, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
# block1_1
(downsample): Sequential(
(0): AvgPool2d(kernel_size=1, stride=1, padding=0)------------------1
(1): Conv2d(64, 256, kernel_size=(1, 1), stride=(1, 1), bias=False) 7
(2): BatchNorm2d(256, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
ADD(block0_0 , block0_1)=>(relu): ReLU(inplace=True) => OUTPUT
(1): Bottleneck(
# block2
(conv1): Conv2d(256, 64, kernel_size=(1, 1), stride=(1, 1), bias=False)
(conv3): Conv2d(64, 256, kernel_size=(1, 1), stride=(1, 1), bias=False) 10
) => OUPUT'
ADD(OUTPUT , OUTPUT') => (relu): ReLU(inplace=True)
layer_list = ['Conv2d', 'BatchNorm2d',
'Conv2d', 'BatchNorm2d']
weight_key_list = ['layer'+str(layer_number)+'.0.conv1.weight', 'layer'+str(layer_number)+'.0.conv2.weight', 'layer'+str(layer_number)+'.0.conv3.weight']
bn_param_key_list = [
['layer'+str(layer_number)+'.0.bn1.weight', 'layer'+str(layer_number)+'.0.bn1.bias', 'layer'+str(layer_number)+'.0.bn1.running_mean', 'layer'+str(layer_number)+'.0.bn1.running_var'],
['layer'+str(layer_number)+'.0.bn2.weight', 'layer'+str(layer_number)+'.0.bn2.bias', 'layer'+str(layer_number)+'.0.bn2.running_mean', 'layer'+str(layer_number)+'.0.bn2.running_var'],
['layer'+str(layer_number)+'.0.bn3.weight', 'layer'+str(layer_number)+'.0.bn3.bias', 'layer'+str(layer_number)+'.0.bn3.running_mean', 'layer'+str(layer_number)+'.0.bn3.running_var']]
output_size_list = output_size_lists[0]
kernel_size_list = [1, 3, 1]
stride_list = stride_size_lists[0]
block1_0_output_tensor = build_block(network, input_layer.get_output(0), layer_list, weights, weight_key_list,
bn_param_key_list, output_size_list, kernel_size_list, stride_list, 0, 0, padding_mode=padding_mode)
print('block1_0_output_tensor shape: ',block1_0_output_tensor.shape)
layer_list = ['AvgPool2d', 'Conv2d', 'BatchNorm2d']
weight_key_list = ['layer'+str(layer_number)+'.0.downsample.1.weight']
['layer'+str(layer_number)+'.0.downsample.2.weight',
'layer'+str(layer_number)+'.0.downsample.2.bias',
'layer'+str(layer_number)+'.0.downsample.2.running_mean',
'layer'+str(layer_number)+'.0.downsample.2.running_var']]
output_size_list = output_size_lists[1]
kernel_size_list = [1]
stride_list = stride_size_lists[1]
if layer_number == 1:
avg_pool_kernel_size=1
avg_pool_stride_size=1
else:
avg_pool_kernel_size = 2
avg_pool_stride_size = 2
block1_1_output_tensor = build_block(network, input_layer.get_output(0), layer_list, weights, weight_key_list,
avg_pool_kernel_size, avg_pool_stride_size, padding_mode=padding_mode)
print('block1_1_output_tensor shape: ', block1_0_output_tensor.shape) # output_layer.get_output(0).shape[1])
add1 = network.add_elementwise(block1_0_output_tensor, block1_1_output_tensor, trt.ElementWiseOperation.SUM)
assert add1 != None
add1.get_output(0).name = 'Layer_'+str(layer_number)+' Block0 + Block1'
block1_output_layer = network.add_activation(input=add1.get_output(0), type=trt.ActivationType.RELU)
print('block1_output_layer shape: ', block1_output_layer.get_output(0).shape)
weight_key_list = ['layer'+str(layer_number)+'.1.conv1.weight', 'layer'+str(layer_number)+'.1.conv2.weight', 'layer'+str(layer_number)+'.1.conv3.weight']
['layer'+str(layer_number)+'.1.bn1.weight', 'layer'+str(layer_number)+'.1.bn1.bias', 'layer'+str(layer_number)+'.1.bn1.running_mean', 'layer'+str(layer_number)+'.1.bn1.running_var'],
['layer'+str(layer_number)+'.1.bn2.weight', 'layer'+str(layer_number)+'.1.bn2.bias', 'layer'+str(layer_number)+'.1.bn2.running_mean', 'layer'+str(layer_number)+'.1.bn2.running_var'],
['layer'+str(layer_number)+'.1.bn3.weight', 'layer'+str(layer_number)+'.1.bn3.bias', 'layer'+str(layer_number)+'.1.bn3.running_mean', 'layer'+str(layer_number)+'.1.bn3.running_var']]
output_size_list = output_size_lists[2]
stride_list = stride_size_lists[2]
block2_output_tensor = build_block(network, block1_output_layer.get_output(0), layer_list, weights, weight_key_list,
bn_param_key_list, output_size_list, kernel_size_list, stride_list, 0, 0, padding_mode)
print('block2_output_tensor shape: ', block2_output_tensor.shape)
add2 = network.add_elementwise(block1_output_layer.get_output(0), block2_output_tensor,
assert add2 != None
add2.get_output(0).name = 'Layer_'+str(layer_number)+' Block1 + Block2'
block2_output_layer = network.add_activation(input=add2.get_output(0), type=trt.ActivationType.RELU)
print('block2_output_layer shape: ', block2_output_layer.get_output(0).shape)
return block2_output_layer
def populate_network_resnet26d(network, weights):
# Configure the network layers based on the weights provided.
input_tensor = network.add_input(name=ModelData.INPUT_NAME, dtype=ModelData.DTYPE, shape=ModelData.INPUT_SHAPE)
# 1. STEM
(conv1): Sequential((0): Conv2d(3, 32, kernel_size=(3, 3), stride=(2, 2), padding=(1, 1), bias=False)------------------1 224->112
(1): BatchNorm2d(32, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
(2): ReLU(inplace=True)
(3): Conv2d(32, 32, kernel_size=(3, 3), stride=(1, 1), padding=(1, 1), bias=False) 2
(4): BatchNorm2d(32, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
(5): ReLU(inplace=True)
(6): Conv2d(32, 64, kernel_size=(3, 3), stride=(1, 1), padding=(1, 1), bias=False) 3)
layer_list = ['Conv2d', 'BatchNorm2d', 'ReLU',
'Conv2d', 'BatchNorm2d', 'ReLU']
weight_key_list = ['conv1.0.weight', 'conv1.3.weight', 'conv1.6.weight']
bn_param_key_list=[['conv1.1.weight', 'conv1.1.bias', 'conv1.1.running_mean', 'conv1.1.running_var'],
['conv1.4.weight', 'conv1.4.bias', 'conv1.4.running_mean', 'conv1.4.running_var'],
['bn1.weight', 'bn1.bias', 'bn1.running_mean', 'bn1.running_var']]
output_size_list=[32,32,64]
kernel_size_list=[3, 3, 3]
stride_list=[2, 1, 1]
stem_output_tensor=build_block(network, input_tensor, layer_list, weights, weight_key_list, bn_param_key_list, output_size_list, kernel_size_list, stride_list)
#(maxpool): MaxPool2d(kernel_size=3, stride=2, padding=1, dilation=1, ceil_mode=False)----------------- 112->56
maxpool_layer = network.add_pooling(stem_output_tensor, trt.PoolingType.MAX, (3, 3))
maxpool_layer.stride = (2, 2)
maxpool_layer.padding =(1, 1)
print('maxpool_layer shape: ', maxpool_layer.get_output(0).shape)
# 2. Layer 1~4
output_layer1 = build_layer(network, weights, maxpool_layer,1,[[ 64, 64,256], [256], [ 64, 64,256]], [[1, 1, 1], [1], [1, 1, 1]],None)#,trt.PaddingMode.SAME_UPPER None
output_layer2 = build_layer(network, weights, output_layer1, 2,[[128,128,512], [512], [128,128,512]], [[1, 2, 1], [1], [1, 1, 1]],None)#,trt.PaddingMode.EXPLICIT_ROUND_DOWN)
output_layer3 = build_layer(network, weights, output_layer2, 3,[[256,256,1024],[1024],[256,256,1024]], [[1, 2, 1], [1], [1, 1, 1]],None)#,trt.PaddingMode.CAFFE_ROUND_UP)
output_layer4 = build_layer(network, weights, output_layer3, 4,[[512,512,2048],[2048],[512,512,2048]], [[1, 2, 1], [1], [1, 1, 1]],None)#,trt.PaddingMode.SAME_UPPER)
# 2. Layer 2
# 'layer2.0.conv1.weight',
# 'layer2.0.bn1.weight', 'layer2.0.bn1.bias', 'layer2.0.bn1.running_mean', 'layer2.0.bn1.running_var',
# 'layer2.0.conv2.weight',
# 'layer2.0.bn2.weight', 'layer2.0.bn2.bias', 'layer2.0.bn2.running_mean', 'layer2.0.bn2.running_var',
# 'layer2.0.conv3.weight',
# 'layer2.0.bn3.weight', 'layer2.0.bn3.bias', 'layer2.0.bn3.running_mean', 'layer2.0.bn3.running_var',
# 'layer2.0.downsample.1.weight',
# 'layer2.0.downsample.2.weight', 'layer2.0.downsample.2.bias', 'layer2.0.downsample.2.running_mean', 'layer2.0.downsample.2.running_var',
# 'layer2.1.conv1.weight',
# 'layer2.1.bn1.weight', 'layer2.1.bn1.bias', 'layer2.1.bn1.running_mean', 'layer2.1.bn1.running_var',
# 'layer2.1.conv2.weight',
# 'layer2.1.bn2.weight', 'layer2.1.bn2.bias', 'layer2.1.bn2.running_mean', 'layer2.1.bn2.running_var',
# 'layer2.1.conv3.weight',
# 'layer2.1.bn3.weight', 'layer2.1.bn3.bias', 'layer2.1.bn3.running_mean', 'layer2.1.bn3.running_var',
# 'layer3.0.conv1.weight',
# 'layer3.0.bn1.weight', 'layer3.0.bn1.bias', 'layer3.0.bn1.running_mean', 'layer3.0.bn1.running_var',
# 'layer3.0.conv2.weight',
# 'layer3.0.bn2.weight', 'layer3.0.bn2.bias', 'layer3.0.bn2.running_mean', 'layer3.0.bn2.running_var',
# 'layer3.0.conv3.weight',
# 'layer3.0.bn3.weight', 'layer3.0.bn3.bias', 'layer3.0.bn3.running_mean', 'layer3.0.bn3.running_var',
# 'layer3.0.downsample.1.weight',
# 'layer3.0.downsample.2.weight', 'layer3.0.downsample.2.bias', 'layer3.0.downsample.2.running_mean', 'layer3.0.downsample.2.running_var',
# 'layer3.1.conv1.weight',
# 'layer3.1.bn1.weight', 'layer3.1.bn1.bias', 'layer3.1.bn1.running_mean', 'layer3.1.bn1.running_var',
# 'layer3.1.conv2.weight',
# 'layer3.1.bn2.weight', 'layer3.1.bn2.bias', 'layer3.1.bn2.running_mean', 'layer3.1.bn2.running_var',
# 'layer3.1.conv3.weight',
# 'layer3.1.bn3.weight', 'layer3.1.bn3.bias', 'layer3.1.bn3.running_mean', 'layer3.1.bn3.running_var',
# 'layer4.0.conv1.weight',
# 'layer4.0.bn1.weight', 'layer4.0.bn1.bias', 'layer4.0.bn1.running_mean', 'layer4.0.bn1.running_var',
# 'layer4.0.conv2.weight',
# 'layer4.0.bn2.weight', 'layer4.0.bn2.bias', 'layer4.0.bn2.running_mean', 'layer4.0.bn2.running_var',
# 'layer4.0.conv3.weight',
# 'layer4.0.bn3.weight', 'layer4.0.bn3.bias', 'layer4.0.bn3.running_mean', 'layer4.0.bn3.running_var',
# 'layer4.0.downsample.1.weight',
# 'layer4.0.downsample.2.weight', 'layer4.0.downsample.2.bias', 'layer4.0.downsample.2.running_mean', 'layer4.0.downsample.2.running_var',
# 'layer4.1.conv1.weight',
# 'layer4.1.bn1.weight', 'layer4.1.bn1.bias', 'layer4.1.bn1.running_mean', 'layer4.1.bn1.running_var',
# 'layer4.1.conv2.weight',
# 'layer4.1.bn2.weight', 'layer4.1.bn2.bias', 'layer4.1.bn2.running_mean', 'layer4.1.bn2.running_var',
# 'layer4.1.conv3.weight',
# 'layer4.1.bn3.weight', 'layer4.1.bn3.bias', 'layer4.1.bn3.running_mean', 'layer4.1.bn3.running_var',
# 'fc.weight', 'fc.bias'])
# (fc): Linear(in_features=2048, out_features=1000, bias=True)
output_layer5 = network.add_pooling(output_layer4.get_output(0), trt.PoolingType.AVERAGE, (7, 7))
output_layer5.stride = (1, 1)
output_layer5.padding = (0, 0)
fc_w = weights['fc.weight'].numpy()
fc_b = weights['fc.bias'].numpy()
fc = network.add_fully_connected(output_layer5.get_output(0), ModelData.OUTPUT_SIZE, fc_w, fc_b)
fc.get_output(0).name = ModelData.OUTPUT_NAME
print('FC LAYER shape: ', fc.get_output(0).shape)
network.mark_output(tensor=fc.get_output(0))
def tmp():
#(relu): ReLU(inplace=True)
#layer1-BOTTLENECK0
#(conv1): Conv2d(64, 64, kernel_size=(1, 1), stride=(1, 1), bias=False)
layer1_bottleneck0_conv1 = layer_conv(network, maxpool.get_output(0), weights['layer1.0.conv1.weight'].numpy(), 64, kernel_size=(1, 1), stride=(1, 1))
#(bn1): BatchNorm2d(64, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
layer1_bottleneck0_bn1 = layer_bn(network, layer1_bottleneck0_conv1.get_output(0), weights['layer1.0.bn1.weight'].numpy(),
weights['layer1.0.bn1.bias'].numpy(),
weights['layer1.0.bn1.running_mean'].numpy(),
weights['layer1.0.bn1.running_var'].numpy())
#(conv2): Conv2d(64, 64, kernel_size=(3, 3), stride=(1, 1), padding=(1, 1), bias=False)
layer1_bottleneck0_conv2_w = weights['layer1.0.conv2.weight'].numpy()
layer1_bottleneck0_conv2 = network.add_convolution(input=layer1_bottleneck0_bn1.get_output(0), num_output_maps=64,
kernel_shape=(3, 3),
kernel=layer1_bottleneck0_conv2_w,
#(bn2): BatchNorm2d(64, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
layer1_bottleneck0_bn2 = layer_bn(network, layer1_bottleneck0_conv2.get_output(0), weights['layer1.0.bn2.weight'].numpy(),
weights['layer1.0.bn2.bias'].numpy(),
weights['layer1.0.bn2.running_mean'].numpy(),
weights['layer1.0.bn2.running_var'].numpy())
#(conv3): Conv2d(64, 256, kernel_size=(1, 1), stride=(1, 1), bias=False)
layer1_bottleneck0_conv3_w = weights['layer1.0.conv3.weight'].numpy()
layer1_bottleneck0_conv3 = network.add_convolution(input=layer1_bottleneck0_bn2.get_output(0),
#(bn3): BatchNorm2d(256, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
layer1_bottleneck0_bn3 = layer_bn(network, layer1_bottleneck0_conv3.get_output(0), weights['layer1.0.bn3.weight'].numpy()
, weights['layer1.0.bn3.bias'].numpy()
, weights['layer1.0.bn3.running_mean'].numpy()
, weights['layer1.0.bn3.running_var'].numpy())
layer1_bottleneck0_relu = network.add_activation(input=layer1_bottleneck0_bn3.get_output(0), type=trt.ActivationType.RELU)
# (downsample): Sequential
# (0): AvgPool2d(kernel_size=1, stride=1, padding=0)
# (1): Conv2d(64, 256, kernel_size=(1, 1), stride=(1, 1), bias=False)
# (2): BatchNorm2d(256, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
layer1_bottleneck0_downsample_avgpool = network.add_pooling(layer1_bottleneck0_relu.get_output(0), trt.PoolingType.AVERAGE, (1, 1))
layer1_bottleneck0_downsample_avgpool.stride = (1, 1)
layer1_bottleneck0_downsample_conv_w = weights['layer1.0.downsample.1.weight'].numpy()
layer1_bottleneck0_downsample_conv = network.add_convolution( input=layer1_bottleneck0_bn1.get_output(0), num_output_maps=256,
kernel_shape=(1, 1),
kernel=layer1_bottleneck0_downsample_conv_w,
layer1_bottleneck0_downsample_bn = layer_bn(network, layer1_bottleneck0_downsample_conv.get_output(0)
, weights['layer1.0.downsample.2.weight'].numpy()
, weights['layer1.0.downsample.2.bias'].numpy()
, weights['layer1.0.downsample.2.running_mean'].numpy()
, weights['layer1.0.downsample.2.running_var'].numpy())
#layer1-Bottleneck1
# (conv1): Conv2d(256, 64, kernel_size=(1, 1), stride=(1, 1), bias=False)
layer1_bottleneck1_conv1_w = weights['layer1.1.conv1.weight'].numpy()
layer1_bottleneck1_conv1_b = np.zeros(64)
layer1_bottleneck1_conv1 = network.add_convolution(input=layer1_bottleneck0_downsample_bn.get_output(0),
num_output_maps=64,
kernel=layer1_bottleneck1_conv1_w,
layer1_bottleneck1_bn1 = layer_bn(network, layer1_bottleneck1_conv1.get_output(0), weights['layer1.1.bn1.weight'].numpy()
, weights['layer1.1.bn1.bias'].numpy()
, weights['layer1.1.bn1.running_mean'].numpy()
, weights['layer1.1.bn1.running_var'].numpy())
# (conv2): Conv2d(64, 64, kernel_size=(3, 3), stride=(1, 1), padding=(1, 1), bias=False)
layer1_bottleneck1_conv2_w = weights['layer1.1.conv2.weight'].numpy()
layer1_bottleneck1_conv2 = network.add_convolution(input=layer1_bottleneck1_bn1.get_output(0),
num_output_maps=64,
kernel=layer1_bottleneck1_conv2_w,
# (bn2): BatchNorm2d(64, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
layer1_bottleneck1_bn2 = layer_bn(network, layer1_bottleneck1_conv2.get_output(0), weights['layer1.1.bn2.weight'].numpy()
, weights['layer1.1.bn2.bias'].numpy()
, weights['layer1.1.bn2.running_mean'].numpy()
, weights['layer1.1.bn2.running_var'].numpy())
# (conv3): Conv2d(64, 256, kernel_size=(1, 1), stride=(1, 1), bias=False)
layer1_bottleneck1_conv3_w = weights['layer1.1.conv3.weight'].numpy()
layer1_bottleneck1_conv3 = network.add_convolution(input=layer1_bottleneck1_bn2.get_output(0),
# (bn3): BatchNorm2d(256, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
layer1_bottleneck1_bn3 = layer_bn(network, layer1_bottleneck1_conv3.get_output(0), weights['layer1.1.bn3.weight'].numpy()
, weights['layer1.1.bn3.bias'].numpy()
, weights['layer1.1.bn3.running_mean'].numpy()
, weights['layer1.1.bn3.running_var'].numpy())
# (relu): ReLU(inplace=True)
layer1_bottleneck1_relu = network.add_activation(input=layer1_bottleneck1_bn3.get_output(0), type=trt.ActivationType.RELU)
# LAYER2-Bottleneck0
# (conv1): Conv2d(256, 128, kernel_size=(1, 1), stride=(1, 1), bias=False)
layer_conv(network, input=layer1_bottleneck1_relu.get_output(0), output_size=128, w=weights['layer2.0.conv1.weight'].numpy(), kernel_size=(1, 1), stride=(1, 1) )
# (bn1): BatchNorm2d(128, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
layer2_bottleneck0_bn1 = layer_bn(network, layer2_bottleneck0_conv1.get_output(0), weights['layer2.0.bn1.weight'].numpy()
, weights['layer2.0.bn1.bias'].numpy()
, weights['layer2.0.bn1.running_mean'].numpy()
, weights['layer2.0.bn1.running_var'].numpy())
# (conv2): Conv2d(128, 128, kernel_size=(3, 3), stride=(2, 2), padding=(1, 1), bias=False)
layer2_bottleneck0_conv2_w = weights['layer2.0.conv2.weight'].numpy()
layer2_bottleneck0_conv2 = network.add_convolution(input=layer2_bottleneck0_bn1.get_output(0),
# (bn2): BatchNorm2d(128, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
layer2_bottleneck0_bn2 = layer_bn(network, layer2_bottleneck0_conv2.get_output(0), weights['layer2.0.bn2.weight'].numpy()
, weights['layer2.0.bn2.bias'].numpy()
, weights['layer2.0.bn2.running_mean'].numpy()
, weights['layer2.0.bn2.running_var'].numpy())
# (conv3): Conv2d(128, 512, kernel_size=(1, 1), stride=(1, 1), bias=False)
layer2_bottleneck0_conv3_w = weights['layer2.0.conv3.weight'].numpy()
layer2_bottleneck0_conv3 = network.add_convolution(input=layer2_bottleneck0_bn2.get_output(0),
# (bn3): BatchNorm2d(512, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
layer2_bottleneck0_bn3 = layer_bn(network, layer2_bottleneck0_conv3.get_output(0), weights['layer2.0.bn3.weight'].numpy()
, weights['layer2.0.bn3.bias'].numpy()
, weights['layer2.0.bn3.running_mean'].numpy()
, weights['layer2.0.bn3.running_var'].numpy())
layer2_bottleneck0_relu =network.add_activation(input=layer2_bottleneck0_bn3.get_output(0), type=trt.ActivationType.RELU)
# (downsample): Sequential(
# (0): AvgPool2d(kernel_size=2, stride=2, padding=0)
# (1): Conv2d(256, 512, kernel_size=(1, 1), stride=(1, 1), bias=False)
# (2): BatchNorm2d(512, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
layer2_bottleneck0_downsample_avgpool = network.add_pooling(layer2_bottleneck0_relu.get_output(0), trt.PoolingType.AVERAGE, (2, 2))
layer2_bottleneck0_downsample_avgpool.stride = (2, 2)
layer2_bottleneck0_downsample_conv_w = weights['layer2.0.downsample.1.weight'].numpy()
layer2_bottleneck0_downsample_conv = network.add_convolution(input=layer2_bottleneck0_downsample_avgpool.get_output(0),
layer2_bottleneck0_downsample_bn = layer_bn(network, layer2_bottleneck0_downsample_conv.get_output(0), weights['layer2.0.downsample.2.weight'].numpy()
, weights['layer2.0.downsample.2.bias'].numpy()
, weights['layer2.0.downsample.2.running_mean'].numpy()
, weights['layer2.0.downsample.2.running_var'].numpy())
# LAYER2-Bottleneck1
# (conv1): Conv2d(512, 128, kernel_size=(1, 1), stride=(1, 1), bias=False)
layer2_bottleneck1_conv1_w = weights['layer2.1.conv1.weight'].numpy()
layer2_bottleneck1_conv1 = network.add_convolution( input=layer2_bottleneck0_downsample_bn.get_output(0),
layer2_bottleneck1_bn1 = layer_bn(network, layer2_bottleneck1_conv1.get_output(0), weights['layer2.1.bn1.weight'].numpy()
, weights['layer2.1.bn1.bias'].numpy()
, weights['layer2.1.bn1.running_mean'].numpy()
, weights['layer2.1.bn1.running_var'].numpy())
# (conv2): Conv2d(128, 128, kernel_size=(3, 3), stride=(1, 1), padding=(1, 1), bias=False)
layer2_bottleneck1_conv2_w = weights['layer2.1.conv2.weight'].numpy()
layer2_bottleneck1_conv2 = network.add_convolution( input=layer2_bottleneck1_bn1.get_output(0),
layer2_bottleneck1_bn2 = layer_bn(network, layer2_bottleneck1_conv2.get_output(0), weights['layer2.1.bn2.weight'].numpy()
, weights['layer2.1.bn2.bias'].numpy()
, weights['layer2.1.bn2.running_mean'].numpy()
, weights['layer2.1.bn2.running_var'].numpy())
layer2_bottleneck1_conv3_w = weights['layer2.1.conv3.weight'].numpy()
layer2_bottleneck1_conv3 = network.add_convolution( input=layer2_bottleneck1_bn2.get_output(0),
layer2_bottleneck1_bn3 = layer_bn(network, layer2_bottleneck1_conv3.get_output(0), weights['layer2.1.bn3.weight'].numpy()
, weights['layer2.1.bn3.bias'].numpy()
, weights['layer2.1.bn3.running_mean'].numpy()
, weights['layer2.1.bn3.running_var'].numpy())
layer2_bottleneck1_relu = network.add_activation(input=layer2_bottleneck1_bn3.get_output(0), type=trt.ActivationType.RELU)
#layer3-Bottleneck0
# (conv1): Conv2d(512, 256, kernel_size=(1, 1), stride=(1, 1), bias=False)
# (bn1): BatchNorm2d(256, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
layer3_bottleneck0_conv1_w = weights['layer3.0.conv1.weight'].numpy()
layer3_bottleneck0_conv1 = network.add_convolution( input=layer2_bottleneck1_relu.get_output(0),
layer3_bottleneck0_bn1 = layer_bn(network, layer3_bottleneck0_conv1.get_output(0), weights['layer3.0.bn1.weight'].numpy()
, weights['layer3.0.bn1.bias'].numpy()
, weights['layer3.0.bn1.running_mean'].numpy()
, weights['layer3.0.bn1.running_var'].numpy())
# (conv2): Conv2d(256, 256, kernel_size=(3, 3), stride=(2, 2), padding=(1, 1), bias=False)
# (bn2): BatchNorm2d(256, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
layer3_bottleneck0_conv2_w = weights['layer3.0.conv2.weight'].numpy()
layer3_bottleneck0_conv2 = network.add_convolution( input=layer3_bottleneck0_bn1.get_output(0),
layer3_bottleneck0_bn2 = layer_bn(network, layer3_bottleneck0_conv2.get_output(0), weights['layer3.0.bn2.weight'].numpy()
, weights['layer3.0.bn2.bias'].numpy()
, weights['layer3.0.bn2.running_mean'].numpy()
, weights['layer3.0.bn2.running_var'].numpy())
# (conv3): Conv2d(256, 1024, kernel_size=(1, 1), stride=(1, 1), bias=False)
# (bn3): BatchNorm2d(1024, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
layer3_bottleneck0_conv3_w = weights['layer3.0.conv3.weight'].numpy()
layer3_bottleneck0_conv3 = network.add_convolution( input=layer3_bottleneck0_bn2.get_output(0),
layer3_bottleneck0_bn3 = layer_bn(network, layer3_bottleneck0_conv3.get_output(0), weights['layer3.0.bn3.weight'].numpy()
, weights['layer3.0.bn3.bias'].numpy()
, weights['layer3.0.bn3.running_mean'].numpy()
, weights['layer3.0.bn3.running_var'].numpy())
layer3_bottleneck0_relu = network.add_activation(input=layer3_bottleneck0_bn3.get_output(0), type=trt.ActivationType.RELU)
layer3_bottleneck0_downsample_avgpool = network.add_pooling(layer3_bottleneck0_relu.get_output(0), trt.PoolingType.AVERAGE, (1, 1))
layer3_bottleneck0_downsample_avgpool.stride = (1, 1)
# (1): Conv2d(512, 1024, kernel_size=(1, 1), stride=(1, 1), bias=False)
# (2): BatchNorm2d(1024, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
layer3_bottleneck0_downsample_conv_w = weights['layer3.0.downsample.1.weight'].numpy()
layer3_bottleneck0_downsample_conv = network.add_convolution( input=layer2_bottleneck0_downsample_avgpool.get_output(0),
layer3_bottleneck0_downsample_bn = layer_bn(network, layer3_bottleneck0_downsample_conv.get_output(0), weights['layer3.0.downsample.2.weight'].numpy()
, weights['layer3.0.downsample.2.bias'].numpy()
, weights['layer3.0.downsample.2.running_mean'].numpy()
, weights['layer3.0.downsample.2.running_var'].numpy())
# layer3-Bottleneck1
# (conv1): Conv2d(1024, 256, kernel_size=(1, 1), stride=(1, 1), bias=False)
layer3_bottleneck1_conv1_w = weights['layer3.1.conv1.weight'].numpy()
layer3_bottleneck1_conv1 = network.add_convolution( input=layer3_bottleneck0_downsample_bn.get_output(0),
layer3_bottleneck1_bn1 = layer_bn(network, layer3_bottleneck1_conv1.get_output(0), weights['layer3.1.bn1.weight'].numpy()
, weights['layer3.1.bn1.bias'].numpy()
, weights['layer3.1.bn1.running_mean'].numpy()
, weights['layer3.1.bn1.running_var'].numpy())
# (conv2): Conv2d(256, 256, kernel_size=(3, 3), stride=(1, 1), padding=(1, 1), bias=False)
layer3_bottleneck1_conv2_w = weights['layer3.1.conv2.weight'].numpy()
layer3_bottleneck1_conv2 = network.add_convolution(input=layer3_bottleneck1_bn1.get_output(0),
layer3_bottleneck1_bn2 = layer_bn(network, layer3_bottleneck1_conv2.get_output(0), weights['layer3.1.bn2.weight'].numpy()
, weights['layer3.1.bn2.bias'].numpy()
, weights['layer3.1.bn2.running_mean'].numpy()
, weights['layer3.1.bn2.running_var'].numpy())
layer3_bottleneck1_conv3_w = weights['layer3.1.conv3.weight'].numpy()
layer3_bottleneck1_conv3_b = np.zeros(512)
layer3_bottleneck1_conv3 = network.add_convolution( input=layer3_bottleneck1_bn2.get_output(0),
num_output_maps=512,
kernel=layer3_bottleneck1_conv3_w,
bias=layer3_bottleneck1_conv3_b)
layer3_bottleneck1_conv3.stride = (1, 1)
layer3_bottleneck1_bn3 = layer_bn(network, layer3_bottleneck1_conv3, weights['layer3.1.bn3.weight'].numpy()
, weights['layer3.1.bn3.bias'].numpy()
, weights['layer3.1.bn3.running_mean'].numpy()
, weights['layer3.1.bn3.running_var'].numpy())
layer3_bottleneck1_relu = network.add_activation(input=layer3_bottleneck1_bn3.get_output(0), type=trt.ActivationType.RELU)
# (layer4): (0): Bottleneck( # (conv1): Conv2d(1024, 512, kernel_size=(1, 1), stride=(1, 1), bias=False)
# (bn1): BatchNorm2d(512, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
layer4_bottleneck0_conv1_w = weights['layer4.0.conv1.weight'].numpy()
layer4_bottleneck0_conv1_b = np.zeros(512)
layer4_bottleneck0_conv1= network.add_convolution( input=layer3_bottleneck1_relu.get_output(0),
kernel=layer4_bottleneck0_conv1_w,
bias=layer4_bottleneck0_conv1_b)
layer4_bottleneck0_conv1.stride = (1, 1)
layer4_bottleneck0_bn1 = layer_bn(network, layer4_bottleneck0_conv1, weights['layer4.0.bn1.weight'].numpy()
, weights['layer4.0.bn1.bias'].numpy()
, weights['layer4.0.bn1.running_mean'].numpy()
, weights['layer4.0.bn1.running_var'].numpy())
# (conv2): Conv2d(512, 512, kernel_size=(3, 3), stride=(2, 2), padding=(1, 1), bias=False)
# (bn2): BatchNorm2d(512, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
layer4_bottleneck0_conv2_w = weights['layer4.0.conv2.weight'].numpy()
layer4_bottleneck0_conv2_b = np.zeros(512)
layer4_bottleneck0_conv2 = network.add_convolution( input=layer4_bottleneck0_bn1.get_output(0),
kernel=layer4_bottleneck0_conv2_w,
bias=layer4_bottleneck0_conv2_b)
layer4_bottleneck0_conv2.stride = (1, 1)
layer4_bottleneck0_bn2 = layer_bn(network, layer4_bottleneck0_conv2, weights['layer4.0.bn2.weight'].numpy()
, weights['layer4.0.bn2.bias'].numpy()
, weights['layer4.0.bn2.running_mean'].numpy()
, weights['layer4.0.bn2.running_var'].numpy())
# (conv3): Conv2d(512, 2048, kernel_size=(1, 1), stride=(1, 1), bias=False)
# (bn3): BatchNorm2d(2048, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
layer4_bottleneck0_conv3_w = weights['layer4.0.conv3.weight'].numpy()
layer4_bottleneck0_conv3_b = np.zeros(512)
layer4_bottleneck0_conv3 = network.add_convolution( input=layer4_bottleneck0_bn2.get_output(0),
kernel=layer4_bottleneck0_conv3_w,
bias=layer4_bottleneck0_conv3_b)
layer4_bottleneck0_conv3.stride = (1, 1)
layer4_bottleneck0_bn3 = layer_bn(network, layer4_bottleneck0_conv3, weights['layer4.0.bn3.weight'].numpy()
, weights['layer4.0.bn3.bias'].numpy()
, weights['layer4.0.bn3.running_mean'].numpy()
, weights['layer4.0.bn3.running_var'].numpy())
layer4_bottleneck0_relu = network.add_activation(input=layer4_bottleneck0_bn3.get_output(0), type=trt.ActivationType.RELU)
layer4_bottleneck0_downsample_avgpool = network.add_pooling(layer4_bottleneck0_relu.get_output(0), trt.PoolingType.AVERAGE, (1, 1))
layer4_bottleneck0_downsample_avgpool.stride = (1, 1)
# (1): Conv2d(1024, 2048, kernel_size=(1, 1), stride=(1, 1), bias=False)
# (2): BatchNorm2d(2048, eps=1e-05, momentum=0.1, affine=True, track_running_stats=True)
layer4_bottleneck0_downsample_conv_w = weights['layer4.0.downsample.1.weight'].numpy()
layer4_bottleneck0_downsample_conv_b = np.zeros(512)
layer4_bottleneck0_downsample_conv = network.add_convolution( input=layer2_bottleneck0_downsample_avgpool.get_output(0),
kernel=layer4_bottleneck0_downsample_conv_w,
bias=layer4_bottleneck0_downsample_conv_b)
layer4_bottleneck0_downsample_conv.stride = (1, 1)
layer4_bottleneck0_downsample_bn = layer_bn(network, layer4_bottleneck0_downsample_conv, weights['layer4.0.downsample.2.weight'].numpy()
, weights['layer4.0.downsample.2.bias'].numpy()
, weights['layer4.0.downsample.2.running_mean'].numpy()
, weights['layer4.0.downsample.2.running_var'].numpy())
# (layer4): (1): Bottleneck(
# (conv1): Conv2d(2048, 512, kernel_size=(1, 1), stride=(1, 1), bias=False)
layer4_bottleneck1_conv1_w = weights['layer4.1.conv1.weight'].numpy()
layer4_bottleneck1_conv1_b = np.zeros(512)
layer4_bottleneck1_conv1 = network.add_convolution( input=layer4_bottleneck0_downsample_bn.get_output(0),
kernel=layer4_bottleneck1_conv1_w,
bias=layer4_bottleneck1_conv1_b)
layer4_bottleneck1_conv1.stride = (1, 1)
layer4_bottleneck1_bn1 = layer_bn(network, layer4_bottleneck1_conv1, weights['layer4.1.bn1.weight'].numpy()
, weights['layer4.1.bn1.bias'].numpy()
, weights['layer4.1.bn1.running_mean'].numpy()
, weights['layer4.1.bn1.running_var'].numpy())
# (conv2): Conv2d(512, 512, kernel_size=(3, 3), stride=(1, 1), padding=(1, 1), bias=False)
layer4_bottleneck1_conv2_w = weights['layer4.1.conv2.weight'].numpy()
layer4_bottleneck1_conv2_b = np.zeros(512)
layer4_bottleneck1_conv2 = network.add_convolution( input=layer4_bottleneck1_bn1.get_output(0),
kernel=layer4_bottleneck1_conv2_w,
bias=layer4_bottleneck1_conv2_b)
layer4_bottleneck1_conv2.stride = (1, 1)
layer4_bottleneck1_bn2 = layer_bn(network, layer4_bottleneck1_conv2, weights['layer4.1.bn2.weight'].numpy()
, weights['layer4.1.bn2.bias'].numpy()
, weights['layer4.1.bn2.running_mean'].numpy()
, weights['layer4.1.bn2.running_var'].numpy())
layer4_bottleneck1_conv3_w = weights['layer4.1.conv3.weight'].numpy()
layer4_bottleneck1_conv3_b = np.zeros(512)
layer4_bottleneck1_conv3 = network.add_convolution( input=layer4_bottleneck1_bn2.get_output(0),
kernel=layer4_bottleneck1_conv3_w,
bias=layer4_bottleneck1_conv3_b)
layer4_bottleneck1_conv3.stride = (1, 1)
layer4_bottleneck1_bn3 = layer_bn(network, layer4_bottleneck1_conv3, weights['layer4.1.bn3.weight'].numpy()
, weights['layer4.1.bn3.bias'].numpy()
, weights['layer4.1.bn3.running_mean'].numpy()
, weights['layer4.1.bn3.running_var'].numpy())
layer4_bottleneck1_relu=network.add_activation(input=layer4_bottleneck1_bn3.get_output(0), type=trt.ActivationType.RELU)
#(global_pool): SelectAdaptivePool2d(output_size=1, pool_type=avg)
layer4_bottleneck1_avgpool = network.add_pooling(layer4_bottleneck1_relu.get_output(0), trt.PoolingType.AVERAGE, (1, 1))
layer4_bottleneck1_avgpool.stride = (1, 1)
#(fc): Linear(in_features=2048, out_features=1000, bias=True)
fc = network.add_fully_connected(layer4_bottleneck1_avgpool.get_output(0), ModelData.OUTPUT_SIZE, fc_w, fc_b)
def populate_network_mnist(network, weights):
conv1_w = weights['conv1.weight'].numpy()
conv1_b = weights['conv1.bias'].numpy()
conv1 = network.add_convolution(input=input_tensor, num_output_maps=20, kernel_shape=(5, 5), kernel=conv1_w,
bias=conv1_b)
pool1 = network.add_pooling(input=conv1.get_output(0), type=trt.PoolingType.MAX, window_size=(2, 2))
pool1.stride = (2, 2)
conv2_w = weights['conv2.weight'].numpy()
conv2_b = weights['conv2.bias'].numpy()
conv2 = network.add_convolution(pool1.get_output(0), 50, (5, 5), conv2_w, conv2_b)
pool2 = network.add_pooling(conv2.get_output(0), trt.PoolingType.MAX, (2, 2))
pool2.stride = (2, 2)
fc1_w = weights['fc1.weight'].numpy()
fc1_b = weights['fc1.bias'].numpy()
fc1 = network.add_fully_connected(input=pool2.get_output(0), num_outputs=500, kernel=fc1_w, bias=fc1_b)
relu1 = network.add_activation(input=fc1.get_output(0), type=trt.ActivationType.RELU)
fc2_w = weights['fc2.weight'].numpy()
fc2_b = weights['fc2.bias'].numpy()
fc2 = network.add_fully_connected(relu1.get_output(0), ModelData.OUTPUT_SIZE, fc2_w, fc2_b)
fc2.get_output(0).name = ModelData.OUTPUT_NAME
network.mark_output(tensor=fc2.get_output(0))
def build_engine(weights):
# For more information on TRT basics, refer to the introductory samples.
with trt.Builder(TRT_LOGGER) as builder, builder.create_network() as network:
builder.max_workspace_size = common.GiB(1)
# Populate the network using weights from the PyTorch model.
#populate_network_mnist(network, weights)
# Build and return an engine.
return builder.build_cuda_engine(network)
# Loads a random test case from pytorch's DataLoader
def load_random_test_case(model, pagelocked_buffer):
# Select an image at random to be the test case.
img, expected_output = model.get_random_testcase()
# Copy to the pagelocked input buffer
np.copyto(pagelocked_buffer, img)
return expected_output
def get_weights_resnet(model):
return model.state_dict()
# Allocate host and device buffers, and create a stream.
def allocate_buffers(engine):
# Determine dimensions and create page-locked memory buffers (i.e. won't be swapped to disk) to hold host inputs/outputs.
h_input = cuda.pagelocked_empty(trt.volume(engine.get_binding_shape(0)), dtype=trt.nptype(ModelData.DTYPE))
h_output = cuda.pagelocked_empty(trt.volume(engine.get_binding_shape(1)), dtype=trt.nptype(ModelData.DTYPE))
# Allocate device memory for inputs and outputs.
d_input = cuda.mem_alloc(h_input.nbytes)
d_output = cuda.mem_alloc(h_output.nbytes)
# Create a stream in which to copy inputs/outputs and run inference.
stream = cuda.Stream()
return h_input, d_input, h_output, d_output, stream
def do_inference(context, h_input, d_input, h_output, d_output, stream):
# Transfer input data to the GPU.
cuda.memcpy_htod_async(d_input, h_input, stream)
# Run inference.
context.execute_async(bindings=[int(d_input), int(d_output)], stream_handle=stream.handle)
# Transfer predictions back from the GPU.
cuda.memcpy_dtoh_async(h_output, d_output, stream)
# Synchronize the stream
stream.synchronize()
# The Caffe path is used for Caffe2 models.
def build_engine_caffe(model_file, deploy_file):
# You can set the logger severity higher to suppress messages (or lower to display more messages).
with trt.Builder(TRT_LOGGER) as builder, builder.create_network() as network, trt.CaffeParser() as parser:
# Workspace size is the maximum amount of memory available to the builder while building an engine.
# It should generally be set as high as possible.
# Load the Caffe model and parse it in order to populate the TensorRT network.
# This function returns an object that we can query to find tensors by name.
model_tensors = parser.parse(deploy=deploy_file, model=model_file, network=network, dtype=ModelData.DTYPE)
# For Caffe, we need to manually mark the output of the network.
# Since we know the name of the output tensor, we can find it in model_tensors.
network.mark_output(model_tensors.find(ModelData.OUTPUT_NAME))
def load_normalized_test_case(test_image, pagelocked_buffer):
# Converts the input image to a CHW Numpy array
def normalize_image(image):
# Resize, antialias and transpose the image to CHW.
c, h, w = ModelData.INPUT_SHAPE
return np.asarray(image.resize((w, h), Image.ANTIALIAS)).transpose([2, 0, 1]).astype(trt.nptype(ModelData.DTYPE)).ravel()
# Normalize the image and copy to pagelocked memory.
np.copyto(pagelocked_buffer, normalize_image(Image.open(test_image)))
return test_image
def main():
# Set the data path to the directory that contains the trained models and test images for inference.
_, data_files = common.find_sample_data(description="Runs a ResNet50 network with a TensorRT inference engine.",
subfolder="resnet50",
find_files=["binoculars.jpeg", "reflex_camera.jpeg", "tabby_tiger_cat.jpg",
ModelData.MODEL_PATH, ModelData.DEPLOY_PATH,
"class_labels.txt"])
# Get test images, models and labels.
test_images = data_files[0:3]
_, _, labels_file = data_files[3:]
labels = open(labels_file, 'r').read().split('\n')
m = timm.create_model('resnet26d', pretrained=True)
m.eval()
weights = get_weights_resnet(m)
with build_engine(weights) as engine:
#with open("resnet26d.engine", "wb") as f:
# f.write(engine.serialize())
# Inference is the same regardless of which parser is used to build the engine, since the model architecture is the same.
# Build an engine, allocate buffers and create a stream.
# For more information on buffer allocation, refer to the introductory samples.
#inputs, outputs, bindings, stream = common.allocate_buffers(engine)
# Allocate buffers and create a CUDA stream.
h_input, d_input, h_output, d_output, stream = allocate_buffers(engine)
# Contexts are used to perform inference.
with engine.create_execution_context() as context:
# Load a normalized test case into the host input page-locked buffer.
test_image = random.choice(test_images)
test_case = load_normalized_test_case(test_image, h_input)
# Run the engine. The output will be a 1D tensor of length 1000, where each value represents the
# probability that the image corresponds to that label
for i in range(10):
#torch.cuda.synchronize()
now = time.time()
print('elapsed time:', time.time() - now)
# We use the highest probability as our prediction. Its index corresponds to the predicted label.
pred = labels[np.argmax(h_output)]
if "_".join(pred.split()) in os.path.splitext(os.path.basename(test_case))[0]:
print("Correctly recognized " + test_case + " as " + pred)
else:
print("Incorrectly recognized " + test_case + " as " + pred)
print('end')
def main2():
_, _ = common.find_sample_data(description="Runs an MNIST network using a PyTorch model", subfolder="mnist")
# Train the PyTorch model
mnist_model = model.MnistModel()
mnist_model.learn()
weights = mnist_model.get_weights()
# Do inference with TensorRT.
case_num = load_random_test_case(mnist_model, pagelocked_buffer=inputs[0].host)
# For more information on performing inference, refer to the introductory samples.
# The common.do_inference function will return a list of outputs - we only have one in this case.
[output] = common.do_inference(context, bindings=bindings, inputs=inputs, outputs=outputs, stream=stream)
pred = np.argmax(output)
print("Test Case: " + str(case_num))
print("Prediction: " + str(pred))
if __name__ == '__main__':
main()
I could convert and run TRT engine without any error but unfortunately got wrong prediction result.
I think maybe the reason for this issue comes from my custom batch normalization function
with above function, I have copied all pytorch’s batch norm parameters(such as “xxx.weight/xxx.bias/xxx.running_mean/xxx.running_var/” corresponding to “gamma/beta/mean/var” for batchnorm)
but
I also checked another ticket “TensorRT4:How to do BatchNorm in scale layer? - TensorRT - NVIDIA Developer Forums” but I couldn’t get any hint.
Please try to copy and paste the above code and help me ~!
Thank you~!
