[HELP] Need the raw data of CVB EEPROM for P3737-A04
Hi all,
As the title, Could you do me a favor?
Due to BOM cost issue, we’ve a try to remove CVB EEPROM from P3737-A04. Unfortunately board pad was damaged on U501 (AT24C02D). Cause of the problem we would like to rework circuit to connect ext-EEPROM for function correctly. Our Jetson Orin Developer Kit Carrier Board is 600-13737-000-400 & PCB VER: P3737-A04. Many thanks!
Moving to Jetson Orin forum
We don’t provide raw data on carrier board. Please copy it from other fine board if you have.
