I need some help in trying to create a memory buffer that can store two images.
I am not sure how to write a program which is correct because everything I write leads to an infinite loop or creates another problem.
The following is the code which I adapted from the CUDA/OpenGL interop lesson in ‘CUDA-By Example’. Any help in writing the program is REALLY appreciated.
#include “book.h”
#include “cpu_bitmap.h”
#include “cuda.h”
#include <cuda_gl_interop.h>
PFNGLBINDBUFFERARBPROC glBindBuffer = NULL;
PFNGLDELETEBUFFERSARBPROC glDeleteBuffers = NULL;
PFNGLGENBUFFERSARBPROC glGenBuffers = NULL;
PFNGLBUFFERDATAARBPROC glBufferData = NULL;
#define DIM 512
#define IMAGESIZE_MAX (DIM*DIM)
GLuint bufferObj;
cudaGraphicsResource *resource;
// based on ripple code, but uses uchar4 which is the type of data
// graphic inter op uses. see screenshot - basic2.png
global void kernel( uchar4 *ptr1) {
// map from threadIdx/BlockIdx to pixel position
int x = threadIdx.x + blockIdx.x * blockDim.x;
int y = threadIdx.y + blockIdx.y * blockDim.y;
int offset = x + y * blockDim.x * gridDim.x ;
// now calculate the value at that position
float fx = x/(float)DIM - 0.5f;
float fy = y/(float)DIM - 0.5f;
unsigned char green = 128 + 127 * tan( abs(fx*100) - abs(fy*100) );
// accessing uchar4 vs unsigned char*
ptr1[offset].x = 0;
ptr1[offset].y = green;
ptr1[offset].z = 0;
ptr1[offset].w = 255;
global void kernel2( uchar4 *ptr2) {
ptr2[offset].x = 1000;
ptr2[offset].y = green;
ptr2[offset].z = 0;
ptr2[offset].w = 255;
void key_func( unsigned char key, int x, int y ) {
switch (key) {
case 27:
// clean up OpenGL and CUDA
( cudaGraphicsUnregisterResource( resource ) );
glBindBuffer( GL_PIXEL_UNPACK_BUFFER_ARB, 0 );
glDeleteBuffers( 1, &bufferObj );
exit(0);
void draw_func( void ) {
// we pass zero as the last parameter, because out bufferObj is now
// the source, and the field switches from being a pointer to a
// bitmap to now mean an offset into a bitmap object
glDrawPixels( DIM, DIM, GL_RGBA, GL_UNSIGNED_BYTE, 0 );
glutSwapBuffers();
int main( int argc, char **argv ) {
cudaDeviceProp prop;
int dev;
memset( &prop, 0, sizeof( cudaDeviceProp ) );
prop.major = 1;
prop.minor = 0;
( cudaChooseDevice( &dev, &prop ) );
// tell CUDA which dev we will be using for graphic interop
// from the programming guide: Interoperability with OpenGL
// requires that the CUDA device be specified by
// cudaGLSetGLDevice() before any other runtime calls.
( cudaGLSetGLDevice( dev ) );
// these GLUT calls need to be made before the other OpenGL
// calls, else we get a seg fault
glutInit( &argc, argv );
glutInitDisplayMode( GLUT_DOUBLE | GLUT_RGBA );
glutInitWindowSize( DIM, DIM );
glutCreateWindow( "bitmap" );
glBindBuffer = (PFNGLBINDBUFFERARBPROC)GET_PROC_ADDRESS("glBindBuffer");
glDeleteBuffers = (PFNGLDELETEBUFFERSARBPROC)GET_PROC_ADDRESS("glDeleteBuffers");
glGenBuffers = (PFNGLGENBUFFERSARBPROC)GET_PROC_ADDRESS("glGenBuffers");
glBufferData = (PFNGLBUFFERDATAARBPROC)GET_PROC_ADDRESS("glBufferData");
// the first three are standard OpenGL, the 4th is the CUDA reg
// of the bitmap these calls exist starting in OpenGL 1.5
glGenBuffers( 1, &bufferObj );
glBindBuffer( GL_PIXEL_UNPACK_BUFFER_ARB, bufferObj );
glBufferData( GL_PIXEL_UNPACK_BUFFER_ARB, DIM * DIM * 4 ,
NULL, GL_DYNAMIC_DRAW_ARB );
// REGISTER THE GL BufferObj and CUDA Resource
( cudaGraphicsGLRegisterBuffer( &resource,
bufferObj,
cudaGraphicsMapFlagsNone ) );
// do work with the memory dst being on the GPU, gotten via mapping
HANDLE_ERROR( cudaGraphicsMapResources( 1, &resource, NULL ) );
uchar4* devPtr;
size_t size ;
cudaMalloc ( (uchar4 **)&devPtr, size);
uchar4 *devPtr2;
cudaMalloc ( (uchar4 **)&devPtr2, size);
uchar4 *pBuffer;
(cudaMalloc ( (uchar4 **)&pBuffer, size));
uchar4 *pBufferCurrent;
uchar4 *pBufferImage;
(cudaMalloc ( (uchar4 **)&pBufferImage, size));
HANDLE_ERROR(
cudaGraphicsResourceGetMappedPointer( (void**)&pBufferImage,
&size,
resource) );
dim3 grids(DIM/16,DIM/16);
dim3 threads(16,16);
kernel<<<grids,threads>>>( devPtr );
// kernel2<<<grids,threads>>>(devPtr2);
int a = 1;
do
cudaMemcpy ( pBufferImage, devPtr, size, cudaMemcpyDeviceToDevice);
a++;
} while (a==1);
// REGISTER THE C BUFFER and CUDA Resource
HANDLE_ERROR ( cudaGraphicsUnmapResources( 1, &resource, NULL ) );
// set up GLUT and kick off main loop
glutKeyboardFunc( key_func );
glutDisplayFunc( draw_func );
glutMainLoop();
