Hello all,
I’m new to TLT, and facing some difficulties to run training within Singularity, hope you might be able to help
my setup info:
• Hardware: GPU cluster contains 4 GPUs Tesla V100
• Network Type: Yolo_v4
• TLT Version: tlt_version: 3.0 and docker_tag: v3.0-py3
I was able to run the pre-flight check with no problem:
singularity run --nv docker://nvcr.io/hpc/preflightcheck:20.11
INFO: Creating SIF file…
INFO: The NVIDIA Driver was detected.
INFO: NVRM version: NVIDIA UNIX x86_64 Kernel Module 460.73.01 Thu Apr 1 21:40:36 UTC 2021
INFO: Found CUDA driver library: /.singularity.d/libs/libcuda.so.1
INFO: Latest CUDA supported version: 11020
INFO: Number of GPUs detected: 4
INFO: Detected Mellanox OFED version 5.0-0
WARNING: Unable to determine nv_peer_mem version
INFO: Number of InfiniBand devices detected: 1
• my spec file is almost the same as the sample file
yolo_v4_train_resnet18_kitti.txt (2.1 KB)
• i’m also able to build the singularity image from the following def-file:
tlt_image_test.def (1.4 KB)
• How to reproduce the issue:
the issue is when running the singularity image i get the following error:
singularity run --nv --bind ${LOCAL_DATA}/datasets/Kitti_Vision_OD2012/data:/workspace/tlt-experiments/data ./tlt_image_test.sif
Running from within singularity now
2021-06-23 15:22:49,726 [INFO] root: Registry: ['nvcr.io']
File "/usr/local/lib/python3.6/dist-packages/urllib3/connectionpool.py", line 677, in urlopen
chunked=chunked,
File "/usr/local/lib/python3.6/dist-packages/urllib3/connectionpool.py", line 392, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/lib/python3.6/http/client.py", line 1281, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/lib/python3.6/http/client.py", line 1327, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/lib/python3.6/http/client.py", line 1276, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/lib/python3.6/http/client.py", line 1042, in _send_output
self.send(msg)
File "/usr/lib/python3.6/http/client.py", line 980, in send
self.connect()
File "/usr/local/lib/python3.6/dist-packages/docker/transport/unixconn.py", line 43, in connect
sock.connect(self.unix_socket)
FileNotFoundError: [Errno 2] No such file or directory
During handling of the above exception, another exception occurred:
File "/usr/local/lib/python3.6/dist-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/local/lib/python3.6/dist-packages/urllib3/connectionpool.py", line 727, in urlopen
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File "/usr/local/lib/python3.6/dist-packages/urllib3/util/retry.py", line 403, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/local/lib/python3.6/dist-packages/urllib3/packages/six.py", line 734, in reraise
raise value.with_traceback(tb)
chunked=chunked,
self.send(msg)
self.connect()
urllib3.exceptions.ProtocolError: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
File "/usr/local/lib/python3.6/dist-packages/docker/api/client.py", line 205, in _retrieve_server_version
return self.version(api_version=False)["ApiVersion"]
File "/usr/local/lib/python3.6/dist-packages/docker/api/daemon.py", line 181, in version
return self._result(self._get(url), json=True)
File "/usr/local/lib/python3.6/dist-packages/docker/utils/decorators.py", line 46, in inner
return f(self, *args, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/docker/api/client.py", line 228, in _get
return self.get(url, **self._set_request_timeout(kwargs))
File "/usr/local/lib/python3.6/dist-packages/requests/sessions.py", line 543, in get
return self.request('GET', url, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/requests/sessions.py", line 530, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.6/dist-packages/requests/sessions.py", line 643, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/requests/adapters.py", line 498, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
File "/usr/local/bin/tlt", line 8, in <module>
sys.exit(main())
File "/usr/local/lib/python3.6/dist-packages/tlt/entrypoint/entrypoint.py", line 114, in main
args[1:]
File "/usr/local/lib/python3.6/dist-packages/tlt/components/instance_handler/local_instance.py", line 259, in launch_command
docker_handler = self.handler_map[
File "/usr/local/lib/python3.6/dist-packages/tlt/components/instance_handler/local_instance.py", line 114, in handler_map
docker_mount_file=os.getenv("LAUNCHER_MOUNTS", DOCKER_MOUNT_FILE)
File "/usr/local/lib/python3.6/dist-packages/tlt/components/docker_handler/docker_handler.py", line 47, in __init__
self._docker_client = docker.from_env()
File "/usr/local/lib/python3.6/dist-packages/docker/client.py", line 85, in from_env
timeout=timeout, version=version, **kwargs_from_env(**kwargs)
File "/usr/local/lib/python3.6/dist-packages/docker/client.py", line 40, in __init__
self.api = APIClient(*args, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/docker/api/client.py", line 188, in __init__
self._version = self._retrieve_server_version()
File "/usr/local/lib/python3.6/dist-packages/docker/api/client.py", line 213, in _retrieve_server_version
'Error while fetching server API version: {0}'.format(e)
docker.errors.DockerException: Error while fetching server API version: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
[dawoud@vca-gpu-211-01 tlt-gpuc]$ singularity run --nv --bind ${LOCAL_DATA}/datasets/Kitti_Vision_OD2012/data:/workspace/tlt-experiments/data ./tlt_image_test.sif
WARNING! Using --password via the CLI is insecure. Use --password-stdin.
WARNING! Your password will be stored unencrypted in /home/fe/dawoud/.docker/config.json.
Configure a credential helper to remove this warning. See
https://docs.docker.com/engine/reference/commandline/login/#credentials-store
Login Succeeded
2021-06-23 15:24:07,389 [INFO] root: Registry: ['nvcr.io']
chunked=chunked,
self.send(msg)
self.connect()
timeout=timeout
chunked=chunked,
self.send(msg)
self.connect()
sys.exit(main())
args[1:]
i know that there is no docker daemon running inside my container nor on the cluster (if there is a workaround it that would be great?) but even without the docker login i get the same error but earlier :
Error while fetching server API version: {0}'.format(e) docker.errors.DockerException: Error while fetching server API version: ('Connection aborted.', FileNotFoundError(2, 'No such file or directory'))
