Based on the provided context, I will provide a comprehensive answer.
The question seems to be related to the Jetson Orin Nano module, specifically the 4GB version. However, the question itself is not clear, and it appears to be a fragment of a sentence.
Assuming the question is about the Jetson Orin Nano 4GB module, I will provide some information about it.
The Jetson Orin Nano 4GB module is a part of the NVIDIA Jetson Orin Nano series, which is a family of system-on-modules (SOMs) designed for edge AI and robotics applications. The module is based on the NVIDIA Ampere architecture and features a quad-core ARM Cortex-A78 CPU, 4GB of LPDDR5 memory, and 16GB of eMMC storage.
According to the provided context, the Jetson Orin Nano 4GB module is supported by the jetson-orin-nano-devkit and jetson-orin-nano-devkit-super configuration files. These configuration files are used to flash the module with the desired software and settings.
The jetson-orin-nano-devkit configuration file is used for the standard development kit, while the jetson-orin-nano-devkit-super configuration file is used for the “Super” configuration, which has a higher power budget and extended clock-frequency steps.
In terms of thermal management, the Jetson Orin Nano module has a thermal design power (TDP) of 10W, and it is recommended to use a heat sink or other cooling solution to ensure proper thermal management.
Compared to other modules in the Jetson Orin Nano series, the 4GB module has less memory and storage than the 8GB module, but it is still a powerful and capable module for edge AI and robotics applications.
In summary, the Jetson Orin Nano 4GB module is a powerful and capable module for edge AI and robotics applications, and it is supported by the jetson-orin-nano-devkit and jetson-orin-nano-devkit-super configuration files. However, the question itself is not clear, and more information is needed to provide a more specific answer.
