Please, can someone explain me in a simple manner when race conditions occurs?
if I do this:
if(a[threadIdx.x+off1]<tex1Dfetch(tex,threadIdx.x+off1))
a[threadIdx.x+off1]=tex1Dfetch(tex,threadIdx.x+off1);
if(a[threadIdx.x+off2]<tex1Dfetch(tex,threadIdx.x+off2))
a[threadIdx.x+off2]=tex1Dfetch(tex,threadIdx.x+off2);
are there race conditions?
thanks in advance for any help.
if I do this:
tera
January 13, 2012, 4:09pm
#3
Yes if more than one thread accesses the same element of [font=“Courier New”]a[/font].
tera
#4
Hi, thank you for your reply. Can you explain me how i can remove it in a simple way? where is exactly the race conditions?
thank in advance
thank in advance
tera
January 14, 2012, 11:44am
#7
My apologies. In this little snippet there is no race condition because the textures are always read at the same index where [font=“Courier New”]a[/font] is written (and textures are read-only), so if any two threads access the same index they will also write the same value (if they write at all), and order doesn’t matter.
tera
#8
no problem, and thank you very much for your help. I have another question :what happens if I don’t use the texture memory? and I do something like that:
float p=-3;
if( label[index+1]>=level && p<phi[index+1])
p= phi[index+1];
if( &label[index-1]>=level && p<phi[index-1])
p=phi[index-1];
if ( label[index+im_r]>=level && p<phi[index+im_r])
p=phi[index+im_r];
if(label[index-im_r]>=level && p<phi[index-im_r])
p=phi[index-im_r];
if (label[index+(im_rim_c)]>=level && p<phi[index+(im_r im_c)])
p=phi[index+(im_r*im_c)];
if(label[index-(im_rim_c)]>=level && p<phi[index-(im_r im_c)])
p=phi[index-(im_r*im_c)];
I think that I’m serializing the access to the same memory location, therefor I would not have race conditions. Is it correct?
I really appreciate your help.
Thanks in advance.
float p=-3;
p= phi[index+1];
p=phi[index-1];
p=phi[index+im_r];
p=phi[index-im_r];
Thanks in advance.
