Yes dude, using CUDA is dangerous! This is why we call it “extrem programming” ;-)
More seriously, using CUDA, you use all the computational power of your graphic card…
If your graphic card becomes very hot, it just means that it’s computing.
If you see fire, maybe it means that your card has some problem (or your code is on fire ;-) )
Yes you are surely right. However, my power supply is a CORSAIR 850W… but the chassis is not sophisticated. Maybe I should buy another one or change the fan.
However, what I fear the most is that since the graphic card is so BIG it almost touches the heat sink of a motherboard chipset :|. If that’s the problem I have to change much more =_=
Anyway, now I opened the chassis and I will make some more trials to see what happens in the CABRIO configuration :).
