Hello! I need to dual boot my Windows 11 system with Ubuntu 22.04.5 LTS (Jammy Jellyfish) to run ROS2, Gazebo and Docker natively. I tried following YT tutorials and yet ran into some errors. I’ll be eternally grateful if anyone could guide me through this :)
1. Search Effort
Several hours on Ubuntu forums, Reddit, and YouTube tutorials about 22.04 dual‑boot and NVIDIA login loop issues.
2. System & Issue
OS: Ubuntu 22.04.5 LTS Desktop, dual boot with Windows 11 Home SL
Hardware: Acer Predator Helios Neo 16S AI – Intel Core Ultra 7 255HX, NVIDIA RTX 5050, 16 GB RAM, 1 TB Micron NVMe
Partitions for Ubuntu: 80 GB ext4
/, 200 GB ext4/home, 20 GB swap -
Boot: GRUB present; Windows Boot Manager in EFI partition
Symptom:
Ubuntu reaches GUI login screen, then loops back after password.
Adding
nomodesetat GRUB → black screen with blinking underscore. -
Windows 11 boots and runs normally.
3. Dual‑Boot Setup (Windows + BIOS steps condensed)
Disabled Windows Fast Startup.
Suspended BitLocker (
Suspend-BitLocker -MountPoint C:), confirmed protection off. -
Booted Windows into Safe Mode using
bcdedit /set {current} safeboot minimal, then reverted. -
In BIOS: disabled Intel VMD controller, left UEFI mode, enabled F12 boot menu, disabled Fast Boot and Secure Boot.
Confirmed Windows now uses “Standard NVM Express Controller” and C: is visible.
Shrunk C: in Disk Management and created 300 GB unallocated space for Ubuntu.
Wrote
ubuntu-22.04.5-desktop-amd64.isoto a SanDisk 32 GB USB with Rufus (GPT, UEFI).
4. Ubuntu Install Choices (where things likely went wrong)
Booted USB with “Try or Install Ubuntu” (not “Ubuntu (safe graphics)”) despite NVIDIA discrete GPU.
Chose “Normal installation” and checked “Install third‑party software (graphics/Wi‑Fi etc.)”.
In “Something else” partitioning: created 80G
/, 200G/home, 20G swap on the Micron NVMe. -
Bootloader target set to entire disk
/dev/nvme0n1instead of the EFI entry/dev/nvme0n1p1 Windows Boot Manager**.**
After install:
First and subsequent boots → login loop.
nomodesettest instead leads to black screen with blinking underscore. -
Recovery mode and new user creation did not restore a working desktop.
5. Current Question
Install is reproducibly broken from first boot onward.
ISO checksum is verified correct.
Windows, BitLocker, and all partitions appear healthy.
Seeking advice on whether to:
Reinstall Ubuntu over existing
/,/home, and swap (possibly using “Ubuntu (safe graphics)” and targeting the EFI “Windows Boot Manager” for GRUB), or -
Attempt repair in place (e.g., reinstall GRUB to EFI and clean up NVIDIA/Nouveau drivers) instead of reinstalling.
Uninstall and restart all over again.
6. Tutorials Followed
How to Enable AHCI Mode Without Reinstalling Windows, INACCESSABLE_BOOT_DEVICE Error 💻🛠️🤔
Changing SATA mode to AHCI (Optane with RAID to AHCI) Acer Predator Helios 300
I’m a noob please help me out T_T
