Help, while installing usd composer it stays stuck on installing
Help, while installing usd composer it stays stuck on installing.
any help is appreciated
Noticed that it stays stuck on GPU_foundation
thank you
Please upload your launcher logs found in the launcher settings panel in the top right corner.
launcher.log (279.6 KB)
yes sir!
@domenico.grillo4 just a passerby, so take my response here with a grain of salt. how many versions of Composer/Create do you have installed previously?
Only one! thx for your reply
i asked because there seems to be reports of a previously downloaded Create (2021.3.8) that can’t be deleted. can you also try launching the OV Launcher as admin and see if that does anything?
I tried in admin mode, it still stays stuck. So sad, i was really looking forward to this.
what GPU do you have?
another thing we can try is to run the Cleanup Tool to reset the Launcher. if you don’t have a lot of project/data information, it should help reset Launcher to initial state and try installing from that point again.
I have a 2080 Ti. ok I will try the cleanup tool! thank you.
it worked! After install I executed omniverse in admin and installed the app.
fantastic! good luck with everything else.
