Hi there,
The Millennial Media SDK (advert provider) now uses .AAR files for deployment.
I’ve tried to use this in our project by doing the following:
Changed the Linker->General->Additional Library Directories to point at the directory with the .aar file in.
Added the name of the .aar file (mm-ad-sdk) to Linker->Input->Additional Dependencies.
The linker fails to find the .aar file with
cannot find -lmm-ad-sdk
collect2.exe : error : ld returned 1 exit status
Build FAILED.
Additional things I’ve tried:
Renaming the .aar file to mmsdk.aar in-case it was getting confused by the dashes in the filename.
Adding .aar to the dependencies with and without the .aar extension.
Is it possible to use .aar files?
Help much appreciated,
Thanks,
Steve.
