I am having problem with nvcc compilation on my Windows 7 64 bits. I have both installed CUDA 32 bits and 64 bits, but it seems the SO just take the CUDA 64bits path when I try to compile a CUDA file. When I manually type the full path of CUDA 32 bits I got a successful compilation, but when I put the same PATH on the system PATH the SO just choose the 64 bits nvcc path that is almos in the finish of system PATH. I placed a txt file as attachment where I’ve describe the steps that I made.
any help is very appreciated
Thanks beforehand for everyone
I don’t know why, but I think my txt file has not attached to the message.
Because of that I’ve transcribed the file contents below
1º I echoed the system path
C:\Users\Eduard\Desktop\projetos\CUDA project>echo %PATH%
C:\Program Files (x86)\Microsoft Visual Studio 9.0\Common7\IDE;C:\Program Files
(x86)\Microsoft Visual Studio 9.0\VC\BIN;C:\Program Files (x86)\Microsoft Visual
Studio 9.0\Common7\Tools;...
2º after, I put the path for the CUDA 32 bits in the system path and echoed the results
set CUDA_PATH=C:\Program Files (x86)\NVIDIA GPU Computing Toolkit\CUDA\v3.2\;
C:\Users\Eduard\Desktop\projetos\CUDA project>set PATH=%CUDA_PATH%;%PATH%
C:\Program Files (x86)\NVIDIA GPU Computing Toolkit\CUDA\v3.2\;C:\Program Files
(x86)\Microsoft Visual Studio 9.0\Common7\IDE;C:\Program Files (x86)\Microsoft V
isual Studio 9.0\VC\BIN;C:\Program Files (x86)\Microsoft Visual Studio 9.0\Commo
n7\Tools;...
C:\Users\Eduard\Desktop\projetos\CUDA project>nvcc main.cpp special.cu
nvcc fatal : Visual Studio configuration file '(null)' could not be found for
installation at 'C:\Program Files (x86)\Microsoft Visual Studio 9.0\VC\BIN/../..
3º I have tested what I did and everything succeded, with nvcc generating a.exe
C:\Users\Eduard\Desktop\projetos\CUDA project>"C:\Program Files (x86)\NVIDIA GPU
Computing Toolkit\CUDA\v3.2\bin\nvcc.exe" main.cpp special.cu
main.cpp
special.cu
tmpxft_00000980_00000000-3_special.cudafe1.gpu
tmpxft_00000980_00000000-9_special.cudafe2.gpu
special.cu
tmpxft_00000980_00000000-3_special.cudafe1.cpp
tmpxft_00000980_00000000-15_special.ii
C:\Users\Eduard\Desktop\projetos\CUDA project>dir
O volume na unidade C é Win 7
O Número de Série do Volume é F8A1-BE86
Pasta de C:\Users\Eduard\Desktop\projetos\CUDA project
06/02/2011 11:55 <DIR> .
06/02/2011 11:55 <DIR> ..
06/02/2011 12:05 69.632 a.exe
(other paths ommited)
4º One more try and some observations...
The ellipsis represents another paths that I have ommited
One of them is the path of CUDA 64 bits installation
Though I don't have an edition of MSVC 64 bits
But in my knowledge the SO takes the first executable that
matches on the PATH, but in some way it was using the
path of CUDA 64.
I've tried include the CUDA 32 bin path like my first entry in PATH, but
it didn't have succeeded:
C:\Users\Eduard\Desktop\projetos\CUDA project>set PATH=%CUDA_PATH%\bin%;%PATH%
nvcc fatal : No input files specified; use option --help for more information
Does somewhere have any idea about like I can compile the code without I always need
to type the entire path on the process?
