Help with connecting Jetson to Carla simulator with Gstreamer
Hello friends,
I’m not very good at gstreamer and I maybe doing something really newbie.
I’m trying to send the camera images from a carla simulator to my Jetson Tx2 to do some image segmentation.
On the PC side, I’m connecting to the carla simulator using a python script that basically launches a pipeline with:
appsrc name=source is-live=true format=GST_FORMAT_TIME caps=video/x-raw,format=BGR,clock-rate=(int)90000,width=640,height=480,framerate=30/1 ! videoconvert ! videorate ! video/x-raw ! x264enc ! rtph264pay ! udpsink host=[Jetson's IP] port=18000 sync=false
Then, I get the appsrc pipeline element from its name and I use this to write frames to it:
def new_frame(self, frame) -> None:
       data = frame.tostring()
       buffer = Gst.Buffer.new_allocate(None, len(data), None)
       buffer.fill(0, data)
       buffer.duration = self.__duration
       ret = self.__appsrc.emit('push-buffer', buffer)
       if ret != Gst.FlowReturn.OK:
              print(ret)
this method is called by the carla’s API callback whenever a frame is available. The frame is a numpy [640, 480, 3] array.
Well, on PC simulating a reader for this code I was able to successfully see the video output, by using the suggested pipeline on videoSource source code
gst-launch-1.0 -v udpsrc port=18000 caps = “application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)H264, payload=(int)96” ! rtph264depay ! decodebin ! videoconvert ! autovideosink
On Jetson:
the same pipeline above reports unsupported codec
video-viewer reports received frames…
C++ code also wont work, it reports invalid frames
for the C++ code i’m instantiating a videoSource object in a pointer and I’m using videoOptions to
config it with
options = new videoOptions();
options->ioType = videoOptions::INPUT;
options->zeroCopy = true;
options->resource = "rtp://[IP]:18000"
options->width = 640;
options->height = 480;
options->codec = videoOptions::CODEC_H264;
options->frameRate = 30.0;
Then I do a
input = videoSource::Create(options);
followed by a input->Open()
And I basically follow the example code to get frames
uchar3 *imgptr = NULL;
input->Capture(&imgptr, timeout)
I’ve also checked the stream for IsStreaming()
But, when I try to get then in C++ code I get [gstreamer] gstDecoder – end of stream (EOS) has been reached, stream has been closed
The same code runs smoothly for Camera input and video input from my dataset (for camera I’m using gstCamera::Create(options), for video input i’m using the same videoSource::Create(options))
What I’m doing wrong? Any tips?
**edited to correct identation/spelling
Hi @cristianoo, to confirm/debug that your Jetson is able to receive the RTP stream, can you first try running video-viewer --input-codec=h264 rtp://@:18000 ?
If that’s unable to view the stream, then I would try running this test pipeline on your PC to generate the stream:
gst-launch-1.0 -v videotestsrc ! video/x-raw,width=300,height=300,framerate=30/1 ! x264enc ! rtph264pay ! udpsink host=[JETSON-IP] port=18000
And if that doesn’t work, it would indicate some networking issue between your PC and Jetson, so check the ifconfig tx/rx packets are increasing on both sides and that there isn’t some firewall/ect blocking the traffic.
Hi !
Ok, so I’ve done the following tests:
  1. running gst-launch-1.0 -v videotestsrc ! video/x-raw,width=300,height=300,framerate=30/1 ! x264enc ! rtph264pay ! udpsink host=[JETSON-IP] port=18000 on the PC and video-viewer --input-codec=h264 on Jetson
    SUCCESS
  2. running gst-launch-1.0 -v videotestsrc ! video/x-raw,width=300,height=300,framerate=30/1 ! x264enc ! rtph264pay ! udpsink host=[JETSON-IP] port=18000 on the PC and my C++ jetson-inference code on the Jetson
    SUCCESS
  3. running my python code on PC and video-viewer --input-codec=h264 on Jetson
    FAIL
NVMEDIA: NVMEDIABufferProcessing: 1504: NvMediaParserParse Unsupported Codec
Event_BlockError from 0BlockH264Dec : Error code - e3040
Blocking error event from 0BlockH264DecNVMEDIA: NvMMLiteNVMEDIADecDoWork: 1982: NVMEDIA Video Dec Unsupported Stream
The same thing that happend with my C++ code.
Well I’m already happy with this because now I know it’s my python code that has issues. Thank you for your help already!
Do you guys have any example / experience on sending video frames as np.arrays through Gstreamer?
Hi @cristianoo, sorry for the delay - I personally don’t, however you may find this post useful:
Thank you for your support.
While I was struggling with my code (which for any reasons can stream to a PC but not to Jetson), I’ve found a possible problem.
Please check:
In a PC (PopOS ubuntu-based, 22.04 gstreamer installed), if I do a
gst-launch-1.0 videotestsrc is-live=true ! videoconvert ! queue ! video/x-raw, width=1920, height=1080 ! openh264enc ! rtph264pay ! udpsink host=[jetson’s IP] port=5000
Then read it on Jetson Tx2 with:
video-viewer --input-codec=h264 rtp://[jetson’s IP]:5000
works like a charm.
But if I change openh264enc to x264enc, video-viewer crashes with a NVMEDIA Video Dec Unsupported Stream
In my workstation I’ve tested the following:
nvcodec: nvh264enc: NVENC H.264 Video Encoder <— crashes video-viewer
openh264: openh264enc: OpenH264 video encoder <— works
x264: x264enc: x264 H.264 Encoder <— crashes video-viewer
Is there any difference? shouldnt all of them work, since its the same protocol?
Also, I’ve found that it works well for x265enc, but not for x264enc
edit: I’ve managed to use VP8 to connect a Carla simulator camera output to the Jetson using the example you provided @dusty_nv, so cool!
Nevertheless, using 264 encoding is really not possible due to Jetson not recognizing the stream.
