Help with CUDA Driver CALL Failed error in IsaacSim 4.5.0
Hello
I’m using Ubuntu 22.04 with IsaacSim 4.5.0.
I’m using the NVIDIA Driver (open Kernel) nvidia-driver-550-open
I’ve done the IsaacSim and ROS2 installation and I’m currently trying to run the Carter Navigation sample scene from the Robotics Examples/ROS2/Navigation.
After pressing the Play button I got the following error in the terminal:
CUDA Driver CALL FAILED at line 522: the provided PTX was compiled with an unsupported toolchain.
[Error][omni.sensors.nv.lidar.lidar_core.plugin] CUDA Driver CALL FAILED at line 548: named symbol not found
[Error][omni.sensors.nv.lidar.lidar_core.plugin] CUDA Driver CALL FAILED at line 259: invalid resource handle
The last error line repeat every frame.
I’ve checked the known issues (Known Issues — Isaac Sim Documentation) and run the following command but nothing change.
export LD_LIBRARY_PATH=</path/to/isaac_sim_installation>/extscache/omni.sensors.nv.common-2.5.0-coreapi+lx64.r.cp310/bin:$LD_LIBRARY_PATH
Could you please tell me how to fix this issue?
I really thank you in advance for your help
Could you follow the instructions in Isaac Sim Requirements — Isaac Sim Documentation to install the recommended driver, and then try running Isaac Sim using the container installation method?
Thank you for your reply.
I’ve compared my setting with another computer setting I’ve set last month.
I was able to solve the CUDA issue with the following change:
  • set NVidia Driver to 570
  • downgrade CUDA toolkit version to 12.8
  • fix an issue I have with docker context
  • add toolkit path to ~/.bashrc
Thank you again for your help and your time
