hi,
friends i need help reagrding the code cudaDecoded3d9.
where will i get the output and how to save the output.
my code exits out at :
if (initCudaResources(argc, argv, g_bInterop, bTCC) == E_FAIL) {
g_bAutoQuit = true;
g_bException = true;
g_bWaived = true;
goto ExitApp;
i dont now wat wrong i am doing , can some1 please help . i am passing parameter as "-decodecuda -nointerop -bubbles_Encoded.264 " where bubbles_Encoded.264 is the encoded file obtained from cudaEncode code.
is am doing anything wrong?
if i don’t use ‘-nointerop’ then too code exits out at “cuD3D9CtxCreate(&g_oContext, &g_oDevice, CU_CTX_BLOCKING_SYNC, g_pD3DDevice)” as this fails.
