I am using an NVidia GTX 1050 as a GPU on my computer running Debian 10. I followed this guide to get the drivers installed :
* Cuda installation guide on Linux
Using the package manager method
Also I compiled ffmpeg using this guide :
* FFMpeg with NVidia gpu guide
Following are the logs from :
- nvidia-smi command
Fri Apr 8 12:21:42 2022
| NVIDIA-SMI 470.103.01 Driver Version: 470.103.01 CUDA Version: 11.4 |
| | | MIG M. |
| 0 NVIDIA GeForce ... On | 00000000:01:00.0 Off | N/A |
| 44% 31C P8 N/A / 75W | 22MiB / 1999MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1073 G /usr/lib/xorg/Xorg 15MiB |
| 0 N/A N/A 1953 G /usr/bin/gnome-shell 3MiB |
- Cuda sample deviceQuery :
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "NVIDIA GeForce GTX 1050"
CUDA Driver Version / Runtime Version 11.4 / 11.4
CUDA Capability Major/Minor version number: 6.1
Total amount of global memory: 2000 MBytes (2097086464 bytes)
(005) Multiprocessors, (128) CUDA Cores/MP: 640 CUDA Cores
GPU Max Clock rate: 1468 MHz (1.47 GHz)
Memory Clock rate: 3504 Mhz
Memory Bus Width: 128-bit
L2 Cache Size: 1048576 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total shared memory per multiprocessor: 98304 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 2 copy engine(s)
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device supports Managed Memory: Yes
Device supports Compute Preemption: Yes
Supports Cooperative Kernel Launch: Yes
Supports MultiDevice Co-op Kernel Launch: Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 1 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 11.4, CUDA Runtime Version = 11.4, NumDevs = 1
Result = PASS
- ffmpeg debug
ffmpeg version N-106534-g487b49d8f2 Copyright (c) 2000-2022 the FFmpeg developers
built with gcc 8 (Debian 8.3.0-6)
configuration: --enable-nonfree --enable-cuda-nvcc --enable-libnpp --extra-cflags=-I/usr/local/cuda/include --extra-ldflags=-L/usr/local/cuda/lib64 --disable-static --enable-shared
libavutil 57. 24.101 / 57. 24.101
libavcodec 59. 25.101 / 59. 25.101
libavformat 59. 20.101 / 59. 20.101
libavdevice 59. 6.100 / 59. 6.100
libavfilter 8. 30.100 / 8. 30.100
libswscale 6. 6.100 / 6. 6.100
libswresample 4. 6.100 / 4. 6.100
Splitting the commandline.
Reading option '-v' ... matched as option 'v' (set logging level) with argument 'debug'.
Reading option '-init_hw_device' ... matched as option 'init_hw_device' (initialise hardware device) with argument 'cuda'.
Finished splitting the commandline.
Parsing a group of options: global .
Applying option v (set logging level) with argument debug.
Applying option init_hw_device (initialise hardware device) with argument cuda.
[AVHWDeviceContext @ 0x559301bd7c40] Loaded lib: libcuda.so.1
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuInit
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuDeviceGetCount
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuDeviceGetAttribute
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuDeviceGetName
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuDeviceComputeCapability
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuCtxCreate_v2
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuCtxSetLimit
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuCtxPushCurrent_v2
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuCtxPopCurrent_v2
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuCtxDestroy_v2
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuMemAlloc_v2
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuMemAllocPitch_v2
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuMemAllocManaged
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuMemsetD8Async
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuMemFree_v2
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuMemcpy
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuMemcpyAsync
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuMemcpy2D_v2
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuMemcpy2DAsync_v2
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuMemcpyHtoD_v2
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuMemcpyHtoDAsync_v2
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuMemcpyDtoH_v2
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuMemcpyDtoHAsync_v2
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuMemcpyDtoD_v2
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuMemcpyDtoDAsync_v2
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuGetErrorName
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuGetErrorString
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuCtxGetDevice
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuDevicePrimaryCtxRetain
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuDevicePrimaryCtxRelease
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuDevicePrimaryCtxSetFlags
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuDevicePrimaryCtxGetState
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuDevicePrimaryCtxReset
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuStreamCreate
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuStreamQuery
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuStreamSynchronize
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuStreamDestroy_v2
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuStreamAddCallback
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuEventCreate
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuEventDestroy_v2
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuEventSynchronize
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuEventQuery
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuEventRecord
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuLaunchKernel
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuLinkCreate
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuLinkAddData
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuLinkComplete
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuLinkDestroy
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuModuleLoadData
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuModuleUnload
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuModuleGetFunction
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuModuleGetGlobal
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuTexObjectCreate
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuTexObjectDestroy
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuGLGetDevices_v2
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuGraphicsGLRegisterImage
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuGraphicsUnregisterResource
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuGraphicsMapResources
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuGraphicsUnmapResources
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuGraphicsSubResourceGetMappedArray
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuDeviceGetUuid
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuImportExternalMemory
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuDestroyExternalMemory
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuExternalMemoryGetMappedBuffer
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuExternalMemoryGetMappedMipmappedArray
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuMipmappedArrayGetLevel
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuMipmappedArrayDestroy
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuImportExternalSemaphore
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuDestroyExternalSemaphore
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuSignalExternalSemaphoresAsync
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuWaitExternalSemaphoresAsync
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuArray3DCreate_v2
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuArrayDestroy
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuEGLStreamProducerConnect
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuEGLStreamProducerDisconnect
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuEGLStreamConsumerDisconnect
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuEGLStreamProducerPresentFrame
[AVHWDeviceContext @ 0x559301bd7c40] Loaded sym: cuEGLStreamProducerReturnFrame
Successfully parsed a group of options.
Hyper fast Audio and Video encoder
usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}...
Use -h to get full help or, even better, run 'man ffmpeg'
- ffmpeg test with hwaccel
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'input.mp4':
Metadata:
major_brand : mp42
minor_version : 0
compatible_brands: mp42mp41isomavc1
creation_time : 2015-08-07T09:13:02.000000Z
Duration: 00:00:30.53, start: 0.000000, bitrate: 411 kb/s
Stream #0:0[0x1](und): Video: h264 (Constrained Baseline) (avc1 / 0x31637661), yuv420p(progressive), 480x270 [SAR 1:1 DAR 16:9], 301 kb/s, 30 fps, 30 tbr, 30 tbn (default)
Metadata:
handler_name : L-SMASH Video Handler
vendor_id : [0][0][0][0]
encoder : AVC Coding
Stream #0:1[0x2](und): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 112 kb/s (default)
Metadata:
handler_name : L-SMASH Audio Handler
File 'output.mp4' already exists. Overwrite? [y/N] Stream mapping:
Stream #0:0 -> #0:0 (h264 (native) -> h264 (h264_nvenc))
Stream #0:1 -> #0:1 (aac (native) -> aac (native))
Press [q] to stop, [?] for help
[h264 @ 0x564f8638d8c0] decoder->cvdl->cuvidGetDecoderCaps(&caps) failed -> CUDA_ERROR_NO_DEVICE: no CUDA-capable device is detected
[h264 @ 0x564f8638d8c0] Failed setup for format cuda: hwaccel initialisation returned error.
As you can see the ffmpeg command throws error : “CUDA_ERROR_NO_DEVICE: no CUDA-capable device is detected”
What am I doing wrong?
