Hello @joe.andolina,
Thanks for getting back!
Your project sounds amazing just from what you mentioned about the HW you are using.
Before trying to answer your questions, please allow me to give you a quick rundown of Docker.
You can think of Docker as a tool that allows you to create “virtual machine instances”, where you can choose the base OS image you are going to be working with, as well as the other extra libraries you need to install on top for you specific use case.
That is the reason we have Dockerfiles. They allow you to define and specify every requirement you need on your custom Docker Image, which ensures consistency, ease of maintenance and replicability.
For instance, you could start with a base Ubuntu image. And, let’s say that for example, you need to install OpenCV for a specific computer vision feature on your application. Then you can make sure to install the OpenCV library on your Dockerfile. So at the end, your custom Docker image is based on Ubuntu, however, it has extra libraries you added specific to your system.
Once you built your image, you can deploy it into a Docker container. Which in essence is like flashing a machine with your image.
Now, let me try to answer your questions one by one.
- Is there a way to take the image and deploy it onto the Jetson without all the additional mumbo jumbo?
Yes. Once you have a custom Docker image that works for you, with all the bells and whistles you need, you can save it and deploy it into other Jetson boards without having to go through the process of building the image again.
In order to achieve this, you have a couple of options:
1.1. You can save the Docker image into a tar file:
docker save --output <your_image_name>.tar your_image_name
copy it over to your Jetson:
scp <your_image_name>.tar <jetson_username>@<jetson_ip>:~/
and docker load it there
ssh <jetson_username>@<jetson_ip>:~/
docker load -i <your_image_name>.tar
1.2. You can push it to docker hub
docker push <your_image_name>
And later docker pull it from your Jetson device
docker pull <your_image_name>
- shouldn’t I be able to reference them from within the image?
If you added all the required dependencies on the Dockerfile for your custom Image, you should definitely be able to use them from inside your container.
- Does the following look right in order to deploy a fresh environment from the docker image in question?
Yes, your Dockerfile will help you create a custom Docker image based on nvcr.io/nvidia/l4t-base:35.4.1, and it also adds some libraries at a host level, as well as installing some other libraries using pip.
Hope this answer helps clearing a bit the fog for you.
Docker at the beginning is a bit of a learning curve since it has a lot of different options and tools, but once you learn to use it, you will love it.
Please let us know if you still have questions, we love to help.
Also, don’t hesitate to reach out if you need some assistance with setting up your Docker, you can contact me directly at support@proventusnova.com.
best regards,
Andrew
