Help with otk-pyoptix
Hello.
I am looking to use the Optix Python bindings from
The installation is
Windows 11 24H2
CUDA - 12.9 - 576
Optix - 9.0.0
The optix module version 0.0.1 builds and installs.
But running python hello.py example results in
  File "C:\********\otk-pyoptix\examples\hello.py", line 8, in <module>
    import optix
ImportError: DLL load failed while importing optix: The specified module could not be found.
I installed the 12* version of the cupy and cuda-python and cuda-bindings python packages, latest ones are 13*. I am assuming they are in sync with the CUDA releases.
Also the README suggests pip install pynvrtc. There is no package by that name but there is a nvidia-cuda-nvrtc
Here is the output of pip list
Package                Version
colorama               0.4.6
cuda-bindings          12.9.2
cuda-pathfinder        1.3.0
cuda-python            12.9.2
cupy-cuda12x           13.6.0
fastrlock              0.8.3
iniconfig              2.1.0
numpy                  2.3.3
nvidia-cuda-nvrtc-cu12 12.9.86
optix                  0.0.1
packaging              25.0
pillow                 11.3.0
pip                    25.2
pluggy                 1.6.0
Pygments               2.19.2
pytest                 8.4.2
pywin32                311
Thank you for reading and for you help.
Let me know if you need more information.
Cheers
Update.
I shifted theimport optix line below the
import cupy  as cp    # CUDA bindings
import numpy as np    # Packing of structures in C-compatible format
import optix
and it is working as expected. showing the green square, and the other examples also need to be modified to work
running import optix on the command line interpreter gives this
>>> import optix
  File "<stdin>", line 1, in <module>
    import platform
And
import cupy
import optix
does not error out.
Cheers
Also, the following
from signal import default_int_handler
from telnetlib import DEBUGLEVEL
in curves.py, can be removed
Thanks for bringing this to our attention. I am not sure why CUPY or NUMPY import prior to optix import would be necessary as optix should not rely on them. And the failure to import platform is strange as well as this is a built-in module. I will look into this.
Hello …
glad to be of help!
Also, this is not required. (it is mentioned in the README)
pip install pynvrtc
Since the examples import nvrtc from cuda_bindings
Cheers
Hello again.
VSCode is not able to autocomplete the module contents, while it is able to autocomplete cupy. I think this is because there is no init.py` in the module. It is a bit annoying to go back and forth to look at the function names or struct names.
Could an __init__.py be added / created.
Cheers and Thank you
