Help with using usb camera with opencv and ml container
Hi
I apologize if this has been answered before, but I am using the latest ml container from ngc, and start it up using the following shell command:
sudo docker run -it --rm --runtime nvidia --network host -v ~/Projects/vision-playground:/playground --device /dev/video0 nvcr.io/nvidia/l4t-ml:r32.5.0-py3
but when I run a simple open_cv program that uses the usb camera at /dev/video0 , I get:
[ WARN:0] global /home/nvidia/host/build_opencv/nv_opencv/modules/videoio/src/cap_gstreamer.cpp (933) open OpenCV | GStreamer warning: Cannot query video position: status=0, value=-1, duration=-1
(python3:37): Gtk-WARNING **: 15:47:45.254: cannot open display:
If use the jetson-inference image it all works.
Thanks for your help
What happens if you change the script to:
cv2.VideoCapture(0, cv2.CAP_V4L2)
Also, to enable the display in the container, run this when launching the container (note the options that I added):
$ sudo xhost +si:localuser:root
$ sudo docker run -it --rm --runtime nvidia --network host \
-v ~/Projects/vision-playground:/playground \
--device /dev/video0 \
-e DISPLAY=$DISPLAY \
-v /tmp/.X11-unix/:/tmp/.X11-unix \
Thanks for the speedy turnaround. Seriously impressed! Even better, it now works. Both suggestions were necessary to getting things to work. Many thanks, and I apologize if this was all documented somewhere.
Is there an easy way to pull the aruco library in? (open-cv contrib?)
bb
This answer is seriously underrated!! Thanks a lot!!
