Hello, I am still studying OptiX.
I think that I am not smart and know little about the context of Optix.
This is not my area of expertise, so forgive me my idiot questions.
Unfortunately, I still have a question about the SDK sample.
in the “optixTutorials - tutorial11.cu”, I added a variable in the closest-hit program. And I modified from Spheric view to Hemi-spheric view.
Later, I printed a variables.
It looked smooth. But when the hit point hit the edge, the value of the variable caused an error.
I wonder if this is my simple mistake or not.
I wonder if anyone else has experienced this.
Another question is, noise was not removed when I started the basic light on the Objact surface. I also wonder if other people have experienced this.
Will you share your code modification so we can see what happened?
Also are you on OptiX 6, or an earlier version?
I don’t understand your noise question. Noise is never removed automatically. If you are expecting the denoiser to run, have a look at how to do that in the optixDenoiser SDK sample.
It may be my problem that I am wrong. But I don’t know if it is.
I will ask this question if I have studied more and I have questions later on.
I had another question, but I was able to solve the question.
However, because I could not delete the topic, I modified the question that I usually had.
Sorry to bother you and thank you for your kindness.
