Thanks for your response. Apologize for neglect the above info and I’ve changed my ethernet connection from external to J14. However, sadly, this doesn’t make any change. The output of
sudo tcpdump -i eth0:400
have output
17:43:29.163230 IP 192.168.1.203.10000 > 192.168.0.25.2369: UDP, length 1262
17:43:29.163243 IP 10.162.110.21.52604 > 10.162.110.24.ssh: Flags <li>, ack 529688, win 4186, options [nop,nop,TS val 3241014381 ecr 166374660], length 0
17:43:29.163308 IP 10.162.110.24.ssh > 10.162.110.21.52604: Flags [P.], seq 530344:530804, ack 109, win 331, options [nop,nop,TS val 166374661 ecr 3241014381], length 460
17:43:29.163410 IP 10.162.110.24.ssh > 10.162.110.21.52604: Flags [P.], seq 530804:530992, ack 109, win 331, options [nop,nop,TS val 166374661 ecr 3241014381], length 188
17:43:29.163472 IP 10.162.110.24.ssh > 10.162.110.21.52604: Flags [P.], seq 530992:531204, ack 109, win 331, options [nop,nop,TS val 166374661 ecr 3241014381], length 212
17:43:29.163481 IP 192.168.1.203.10000 > 192.168.0.25.2369: UDP, length 1262
17:43:29.163496 IP 10.162.110.21.52604 > 10.162.110.24.ssh: Flags <li>, ack 530344, win 4186, options [nop,nop,TS val 3241014381 ecr 166374661], length 0
17:43:29.163674 IP 10.162.110.21.52604 > 10.162.110.24.ssh: Flags <li>, ack 530992, win 4186, options [nop,nop,TS val 3241014382 ecr 166374661], length 0
17:43:29.163695 IP 192.168.1.203.10000 > 192.168.0.25.2369: UDP, length 1262
17:43:29.163700 IP 10.162.110.24.ssh > 10.162.110.21.52604: Flags [P.], seq 531204:531664, ack 109, win 331, options [nop,nop,TS val 166374661 ecr 3241014382], length 460
17:43:29.163803 IP 10.162.110.24.ssh > 10.162.110.21.52604: Flags [P.], seq 531664:531852, ack 109, win 331, options [nop,nop,TS val 166374661 ecr 3241014382], length 188
17:43:29.164006 IP 10.162.110.21.52604 > 10.162.110.24.ssh: Flags <li>, ack 531664, win 4186, options [nop,nop,TS val 3241014382 ecr 166374661], length 0
17:43:29.164024 IP 192.168.1.203.10000 > 192.168.0.25.2369: UDP, length 1262
17:43:29.165605 IP 10.162.110.24.ssh > 10.162.110.21.52604: Flags [P.], seq 531852:532120, ack 109, win 331, options [nop,nop,TS val 166374661 ecr 3241014382], length 268
17:43:29.165704 IP 10.162.110.24.ssh > 10.162.110.21.52604: Flags [P.], seq 532120:532732, ack 109, win 331, options [nop,nop,TS val 166374661 ecr 3241014382], length 612
17:43:29.165729 IP 192.168.1.203.10000 > 192.168.0.25.2369: UDP, length 1262
17:43:29.165902 IP 10.162.110.21.52604 > 10.162.110.24.ssh: Flags <li>, ack 532120, win 4186, options [nop,nop,TS val 3241014384 ecr 166374661], length 0
17:43:29.165919 IP 192.168.1.203.10000 > 192.168.0.25.2369: UDP, length 1262
17:43:29.166180 IP 10.162.110.24.ssh > 10.162.110.21.52604: Flags [P.], seq 532732:532936, ack 109, win 331, options [nop,nop,TS val 166374661 ecr 3241014384], length 204
17:43:29.166282 IP 192.168.1.203.10000 > 192.168.0.25.2369: UDP, length 1262
17:43:29.166297 IP 10.162.110.24.ssh > 10.162.110.21.52604: Flags [P.], seq 532936:533148, ack 109, win 331, options [nop,nop,TS val 166374661 ecr 3241014384], length 212
17:43:29.166392 IP 10.162.110.24.ssh > 10.162.110.21.52604: Flags [P.], seq 533148:533264, ack 109, win 331, options [nop,nop,TS val 166374661 ecr 3241014384], length 116
17:43:29.166460 IP 10.162.110.24.ssh > 10.162.110.21.52604: Flags [P.], seq 533264:533532, ack 109, win 331, options [nop,nop,TS val 166374661 ecr 3241014384], length 268
17:43:29.166476 IP 10.162.110.21.52604 > 10.162.110.24.ssh: Flags <li>, ack 532936, win 4186, options [nop,nop,TS val 3241014384 ecr 166374661], length 0
17:43:29.166490 IP 192.168.1.203.10000 > 192.168.0.25.2369: UDP, length 1262
17:43:29.166569 IP 10.162.110.24.ssh > 10.162.110.21.52604: Flags [P.], seq 533532:533992, ack 109, win 331, options [nop,nop,TS val 166374661 ecr 3241014384], length 460
17:43:29.166596 IP 10.162.110.21.52604 > 10.162.110.24.ssh: Flags <li>, ack 533264, win 4186, options [nop,nop,TS val 3241014384 ecr 166374661], length 0
and when I run
./sample_lidar_replay --protocol=lidar.socket --params=protocol=udp,device=CUSTOM,ip=192.168.1.203,port=2369,decoder=libsample_lidar_plugin.so,scan-frequency=10
I still have
[11-10-2019 17:44:23] Driveworks exception thrown: DW_SAL_CANNOT_INITIALIZE: LidarSocket::checkDeviceData, 192.168.1.203:2369 has no data
Since we only have one E3579 Adaptor, one of the ethernet port is connecting to Hesai Lidar and another one is connecting to the internet. Not sure if this could cause some problem.
