I have tried some methods such as https://community.mellanox.com/s/article/howto-compile-mlnx-ofed-drivers--160---mlnx-ofa-kernel-example-x ,
but cannot pass the test suit of openvswitch.
What do you try to do :
1.Recompile openvswitch with debug info ?
Once your run boot.sh, you can run configure with the option : --with-debug
2.Recompile dpdk with debug info (which version)
If your build is based on meson/ninja
You can choose the buildtype
meson configure -Dbuildtype=debug
3.Recompile MOFED with debug info ?
Under the source of mlnx-ofa-kernel, you can run configure with --with-debug-info
Regards
Marc
