we are using an AutoScaling Group on AWS with EC2 Instances (g5.4xlarge) with Windows Server 2022 to stream via Cloud XR to stream to VR Headsets. So for every start we get a new EC2 instance and we found that then SteamVR usually shows some information around the controllers. That can be hidden by opening the steamVR menu once and closing it again. The Problem is that while the info is visible the Performance in VR is very bad, so we would like to have it deactivated by default. Using steam VR on regular machines the info stays hidden after removing it once, so we are wondering if there is some setting to hide it by default.
Best
Xaver
