High inference time when using tensorrt in jetson nano
Converted keras model to frozen graph (.pb) and used it for trt inference.
my code,
trt_graph = trt.create_inference_graph(
input_graph_def=graph_def,
outputs=outputs,
max_batch_size=12,
max_workspace_size_bytes=1 << 25,
precision_mode=“FP16”)
what are the files needed to troubleshoot? how can I provide them?
What is your use case?
We have TFTRT tutorial for object detection and image classification use case.
Would you mind to check the tutorial first?
[url]https://github.com/tensorflow/tensorrt/tree/master/tftrt/examples[/url]
My use case is to detect face and estimate age,gender & emotion. It is not available in those examples.
The case is a detector with several classifiers.
Here is a similar pipeline and you can start from it with your own model:
[url]https://developer.nvidia.com/deepstream-sdk[/url]
Sathiez were you able to get gender and age on jetson nano working ?
