Hello ,
I am using a NVIDIA Corporation G96 [Quadro FX 380] on a Redhat WS running Kernel 2.6.32-358.6.2.el6.x86_64 . I am experiencing high memory leak on my system . Xorg uses the most memory as per top results for
/usr/bin/Xorg :3 -br -verbose -audit 4 -auth /var/run/gdm/auth-for-gdm-Bd3ojJ/database
I am including my current xorg configuration files for your reference
[root@fw03 ~]# cat /etc/X11/xorg.conf
nvidia-settings: X configuration file generated by nvidia-settings
nvidia-settings: version 319.17 (buildmeister@swio-display-x86-rhel47-06) Thu Apr 25 22:28:13 PDT 2013
Section “ServerLayout”
Identifier “Layout0”
Screen 0 “Screen0” 0 0
Screen 1 “Screen1” 1600 0
InputDevice “Keyboard0” “CoreKeyboard”
InputDevice “Mouse0” “CorePointer”
Option “Xinerama” “1”
EndSection
Section “Files”
FontPath “/usr/share/fonts/default/Type1”
EndSection
Section “InputDevice”
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/input/mice"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
# generated from data in "/etc/sysconfig/keyboard"
Identifier "Keyboard0"
Driver "keyboard"
Option "XkbLayout" "us"
Option "XkbModel" "pc105"
EndSection
Section “Monitor”
# HorizSync source: xconfig, VertRefresh source: xconfig
Identifier "Monitor0"
VendorName "Unknown"
ModelName "CRT-1"
HorizSync 30.0 - 92.0
VertRefresh 48.0 - 85.0
Option "DPMS"
EndSection
Section “Monitor”
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor1"
ModelName "HP LP2065"
Option "DPMS"
EndSection
Section “Device”
Identifier “Device0”
Driver “nvidia”
VendorName “NVIDIA Corporation”
BoardName “Quadro FX 380”
BusID “PCI:15:0:0”
EndSection
Section “Device”
Identifier “Device1”
Driver “nvidia”
BusID “PCI:40:0:0”
EndSection
Section “Screen”
Removed Option “metamodes” “CRT: 1600x1200 +0+0, DFP: nvidia-auto-select +0+0; CRT: nvidia-auto-select +0+0, DFP: 1600x1200 +0+0; CRT: nvidia-auto-select +0+0; CRT: 1600x1200 +0+0; CRT: 1600x1200_65 +0+0; CRT: 1600x1200_60 +0+0; CRT: 1440x900 +0+0; CRT: 1440x900_75 +0+0; CRT: 1440x900_60 +0+0; CRT: 1440x900_60_0 +0+0; CRT: 1400x1050 +0+0; CRT: 1400x1050_60 +0+0; CRT: 1400x1050_60_0 +0+0; CRT: 1360x768 +0+0; CRT: 1280x1024 +0+0; CRT: 1280x1024_75 +0+0; CRT: 1280x1024_60 +0+0; CRT: 1280x960 +0+0; CRT: 1280x960_60 +0+0; CRT: 1280x800 +0+0; CRT: 1280x800_75 +0+0; CRT: 1280x800_60 +0+0; CRT: 1280x800_60_0 +0+0; CRT: 1280x768 +0+0; CRT: 1280x768_75 +0+0; CRT: 1280x768_60 +0+0; CRT: 1280x768_60_0 +0+0; CRT: 1152x864 +0+0; CRT: 1024x768_75 +0+0; CRT: 1024x768_70 +0+0; CRT: 1024x768_60 +0+0; CRT: 848x480 +0+0; CRT: 800x600 +0+0; CRT: 800x600_85_0 +0+0; CRT: 800x600_75 +0+0; CRT: 800x600_72 +0+0; CRT: 800x600_60 +0+0”
Removed Option “metamodes” “nvidia-auto-select +0+0; 1600x1200 +0+0”
Removed Option “metamodes” “CRT: nvidia-auto-select +288+216, DFP: nvidia-auto-select +0+0; DFP: 1600x1200 +0+0”
Removed Option “metamodes” “CRT: 1600x1200 +0+0, DFP: nvidia-auto-select +0+0; DFP: 1600x1200 +0+0”
Removed Option “metamodes” “CRT: 1600x1200_60 +0+0, DFP: nvidia-auto-select +0+0; DFP: 1600x1200 +0+0”
Removed Option “metamodes” “CRT: 1600x1200 +0+0, DFP: 1600x1200_60 +0+0; DFP: 1600x1200 +0+0”
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-0"
Option "metamodes" "CRT: 1600x1200_60 +0+0, DFP: 1600x1200 +0+0; DFP: 1600x1200 +0+0"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section “Screen”
Identifier “Screen1”
Device “Device1”
Monitor “Monitor1”
DefaultDepth 24
Option “Stereo” “0”
Option “nvidiaXineramaInfoOrder” “DFP-1”
Option “metamodes” “DFP-0: nvidia-auto-select +1600+0, DFP-1: 1600x1200 +0+0”
SubSection “Display”
Depth 24
EndSubSection
EndSection
Section “Extensions”
Option “Composite” “Disable”
EndSection
Please let me know your valuable inputs how to fix this issue .
