I think your so-called “these instructions does not work” is due to something else. Those instructions shall work. But if that doesn’t take effect, it means some other bugs got hit.
Were you testing on rel-32.7.2?
Hello, Mr. Wayne WWW
You don’t have to pursue it anymore. Recompiling has solved everything. Probably the cause is an inconsistency between the kernel and the driver.
Just want to clarify something
If Mr. lizardperson recompiled it and everything is working fine, then the sources and documentation should be correct. Apparently a kernel panic happened on his board, but there’s no way to know what caused it anymore.
