Hi, I have noticed that activating the hlsl_use_resource_data
option on an HLSL backend leads to internal errors:
Summary
[error] (MDL) <lambda expression>: J100 compiling LLVM code failed: Call parameter type does not match function signature!
%struct.float3* %2
%Res_data* %6 = call fast <3 x float> @expr_lambda_2_(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%Res_data* %16 = call fast <3 x float> @_ZN5state12adapt_normalERK6float3(%State_core* %1, %struct.float3* %2, <3 x float> %15)
%struct.float3* %2
%Res_data* %4 = call fast <3 x float> @expr_lambda_3_(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%Res_data* %494 = call fast <3 x float> @tex_lookup_float3_3d(%struct.float3* %2, i32 0, <3 x float> %493, i32 0, i32 0, i32 0, <2 x float> <float 0.000000e+00, float 1.000000e+00>, <2 x float> <float 0.000000e+00, float 1.000000e+00>, <2 x float> <float 0.000000e+00, float 1.000000e+00>, float 0.000000e+00)
%struct.float3* %2
%Res_data* %580 = call fast <3 x float> @tex_lookup_float3_3d(%struct.float3* %2, i32 0, <3 x float> %579, i32 0, i32 0, i32 0, <2 x float> <float 0.000000e+00, float 1.000000e+00>, <2 x float> <float 0.000000e+00, float 1.000000e+00>, <2 x float> <float 0.000000e+00, float 1.000000e+00>, float 0.000000e+00)
%struct.float3* %2
%Res_data* %590 = call fast <3 x float> @tex_lookup_float3_3d(%struct.float3* %2, i32 0, <3 x float> %589, i32 0, i32 0, i32 0, <2 x float> <float 0.000000e+00, float 1.000000e+00>, <2 x float> <float 0.000000e+00, float 1.000000e+00>, <2 x float> <float 0.000000e+00, float 1.000000e+00>, float 0.000000e+00)
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%Res_data* %5 = call fast <3 x float> @expr_lambda_2_(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%Res_data* %18 = call fast <3 x float> @_ZN5state12adapt_normalERK6float3(%State_core* %1, %struct.float3* %2, <3 x float> %17)
%struct.float3* %2
%struct.float3* %2
%Res_data* %310 = call fast <3 x float> @tex_lookup_float3_3d(%struct.float3* %2, i32 0, <3 x float> %309, i32 0, i32 0, i32 0, <2 x float> <float 0.000000e+00, float 1.000000e+00>, <2 x float> <float 0.000000e+00, float 1.000000e+00>, <2 x float> <float 0.000000e+00, float 1.000000e+00>, float 0.000000e+00)
%struct.float3* %2
%Res_data* %8 = call fast <3 x float> @expr_lambda_2_(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%struct.float3* %2
%Res_data* %5 = call fast <3 x float> @expr_lambda_3_(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%Res_data* %313 = call fast <3 x float> @tex_lookup_float3_3d(%struct.float3* %2, i32 0, <3 x float> %312, i32 0, i32 0, i32 0, <2 x float> <float 0.000000e+00, float 1.000000e+00>, <2 x float> <float 0.000000e+00, float 1.000000e+00>, <2 x float> <float 0.000000e+00, float 1.000000e+00>, float 0.000000e+00)
%struct.float3* %2
%Res_data* %328 = call fast <3 x float> @tex_lookup_float3_3d(%struct.float3* %2, i32 0, <3 x float> %327, i32 0, i32 0, i32 0, <2 x float> <float 0.000000e+00, float 1.000000e+00>, <2 x float> <float 0.000000e+00, float 1.000000e+00>, <2 x float> <float 0.000000e+00, float 1.000000e+00>, float 0.000000e+00)
%struct.float3* %2
%Res_data* %338 = call fast <3 x float> @tex_lookup_float3_3d(%struct.float3* %2, i32 0, <3 x float> %337, i32 0, i32 0, i32 0, <2 x float> <float 0.000000e+00, float 1.000000e+00>, <2 x float> <float 0.000000e+00, float 1.000000e+00>, <2 x float> <float 0.000000e+00, float 1.000000e+00>, float 0.000000e+00)
%struct.float3* %2
%struct.float3* %2
%Res_data* %21 = call fast <3 x float> @_ZN5state12adapt_normalERK6float3(%State_core* %1, %struct.float3* %2, <3 x float> %20)
%struct.float3* %2
%struct.float3* %2
%Res_data* %15 = call fast <3 x float> @_ZN5state12adapt_normalERK6float3(%State_core* %1, %struct.float3* %2, <3 x float> %14)
%struct.float3* %2
%Res_data* %6 = call fast <3 x float> @expr_lambda_7_(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%Res_data* %12 = call fast float @expr_lambda_8_(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%Res_data* %17 = call fast <3 x float> @_ZN5state12adapt_normalERK6float3(%State_core* %1, %struct.float3* %2, <3 x float> %16)
%struct.float3* %2
%Res_data* %4 = call fast <3 x float> @expr_lambda_5_(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%Res_data* %4 = call fast <3 x float> @expr_lambda_9_(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%Res_data* %10 = call fast float @expr_lambda_6_(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%Res_data* %497 = call fast <3 x float> @tex_lookup_float3_3d(%struct.float3* %2, i32 0, <3 x float> %496, i32 0, i32 0, i32 0, <2 x float> <float 0.000000e+00, float 1.000000e+00>, <2 x float> <float 0.000000e+00, float 1.000000e+00>, <2 x float> <float 0.000000e+00, float 1.000000e+00>, float 0.000000e+00)
%struct.float3* %2
%Res_data* %583 = call fast <3 x float> @tex_lookup_float3_3d(%struct.float3* %2, i32 0, <3 x float> %582, i32 0, i32 0, i32 0, <2 x float> <float 0.000000e+00, float 1.000000e+00>, <2 x float> <float 0.000000e+00, float 1.000000e+00>, <2 x float> <float 0.000000e+00, float 1.000000e+00>, float 0.000000e+00)
%struct.float3* %2
%Res_data* %593 = call fast <3 x float> @tex_lookup_float3_3d(%struct.float3* %2, i32 0, <3 x float> %592, i32 0, i32 0, i32 0, <2 x float> <float 0.000000e+00, float 1.000000e+00>, <2 x float> <float 0.000000e+00, float 1.000000e+00>, <2 x float> <float 0.000000e+00, float 1.000000e+00>, float 0.000000e+00)
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%Res_data* %5 = call fast <3 x float> @expr_lambda_7_(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%struct.float3* %2
%Res_data* %8 = call fast <3 x float> @expr_lambda_7_(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%Res_data* %14 = call fast float @expr_lambda_8_(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%Res_data* %22 = call fast <3 x float> @_ZN5state12adapt_normalERK6float3(%State_core* %1, %struct.float3* %2, <3 x float> %21)
%struct.float3* %2
%Res_data* %6 = call fast <3 x float> @expr_lambda_5_(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%Res_data* %5 = call fast <3 x float> @expr_lambda_9_(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%Res_data* %11 = call fast float @expr_lambda_6_(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%Res_data* %316 = call fast <3 x float> @tex_lookup_float3_3d(%struct.float3* %2, i32 0, <3 x float> %315, i32 0, i32 0, i32 0, <2 x float> <float 0.000000e+00, float 1.000000e+00>, <2 x float> <float 0.000000e+00, float 1.000000e+00>, <2 x float> <float 0.000000e+00, float 1.000000e+00>, float 0.000000e+00)
%struct.float3* %2
%Res_data* %331 = call fast <3 x float> @tex_lookup_float3_3d(%struct.float3* %2, i32 0, <3 x float> %330, i32 0, i32 0, i32 0, <2 x float> <float 0.000000e+00, float 1.000000e+00>, <2 x float> <float 0.000000e+00, float 1.000000e+00>, <2 x float> <float 0.000000e+00, float 1.000000e+00>, float 0.000000e+00)
%struct.float3* %2
%Res_data* %341 = call fast <3 x float> @tex_lookup_float3_3d(%struct.float3* %2, i32 0, <3 x float> %340, i32 0, i32 0, i32 0, <2 x float> <float 0.000000e+00, float 1.000000e+00>, <2 x float> <float 0.000000e+00, float 1.000000e+00>, <2 x float> <float 0.000000e+00, float 1.000000e+00>, float 0.000000e+00)
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%Res_data* %5 = call fast <3 x float> @expr_lambda_5_(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%struct.float3* %2
%Res_data* %11 = call fast float @expr_lambda_8_(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%Res_data* %19 = call fast <3 x float> @_ZN5state12adapt_normalERK6float3(%State_core* %1, %struct.float3* %2, <3 x float> %18)
%struct.float3* %2
%Res_data* %6 = call fast <3 x float> @expr_lambda_7_.68(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%Res_data* %12 = call fast float @expr_lambda_8_.69(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%struct.float3* %2
%Res_data* %4 = call fast <3 x float> @expr_lambda_5_.66(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%Res_data* %4 = call fast <3 x float> @expr_lambda_9_.70(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%Res_data* %10 = call fast float @expr_lambda_6_.67(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%Res_data* %5 = call fast <3 x float> @expr_lambda_7_.68(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%struct.float3* %2
%Res_data* %8 = call fast <3 x float> @expr_lambda_7_.68(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%Res_data* %14 = call fast float @expr_lambda_8_.69(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%struct.float3* %2
%Res_data* %6 = call fast <3 x float> @expr_lambda_5_.66(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%Res_data* %5 = call fast <3 x float> @expr_lambda_9_.70(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%Res_data* %11 = call fast float @expr_lambda_6_.67(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%Res_data* %5 = call fast <3 x float> @expr_lambda_5_.66(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%struct.float3* %2
%Res_data* %11 = call fast float @expr_lambda_8_.69(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%struct.float3* %2
%Res_data* %6 = call fast <3 x float> @expr_lambda_3_.91(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%struct.float3* %2
%Res_data* %4 = call fast <3 x float> @expr_lambda_2_.90(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%Res_data* %8 = call fast <3 x float> @expr_lambda_3_.91(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%struct.float3* %2
%Res_data* %5 = call fast <3 x float> @expr_lambda_2_.90(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%Res_data* %5 = call fast <3 x float> @expr_lambda_3_.91(%State_core* %1, %struct.float3* %2)
%struct.float3* %2
[error] (Compiler Backend) <lambda expression>: J100 compiling LLVM code failed: Call parameter type does not match function signature!
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
%struct.float3* %2
I was expecting the code generation to work. Am I missing something in my setup?
Basically, I create a link unit
mi::base::Handle<mi::neuraylib::ILink_unit> linkUnit(m_backend->create_link_unit(m_transaction.get(), m_context.get()));
and register multiple target functions:
std::vector<mi::neuraylib::Target_function_description> genFunctions;
genFunctions.push_back(mi::neuraylib::Target_function_description("surface.scattering", scatteringFuncName.c_str()));
genFunctions.push_back(mi::neuraylib::Target_function_description("surface.emission.emission", emissionFuncName.c_str()));
genFunctions.push_back(mi::neuraylib::Target_function_description("surface.emission.intensity", emissionIntensityFuncName.c_str()));
genFunctions.push_back(mi::neuraylib::Target_function_description("thin_walled", thinWalledFuncName.c_str()));
genFunctions.push_back(mi::neuraylib::Target_function_description("geometry.cutout_opacity", opacityFuncName.c_str()));
mi::Sint32 result = linkUnit->add_material(
compiledMaterial,
genFunctions.data(),
genFunctions.size(),
m_context.get()
Furthermore, I noticed that there’s an undocumented glsl_use_resource_data
backend option.
Is the documentation just missing or is this feature not officially supported?
