Holoscan SDK 4.2.0 container and VPI
Environment:
  • Hardware: Jetson Orin AGX 64GB + Leopard Imaging Camera (Firmware v2510)
  • OS: JetPack 6.2.2 (Network interface configured)
  • Container: clara-holoscan:4.2.0 (Runs Python 3.12)
I followed the Holoscan SDK setup guide, updated the camera firmware, and built/started the Holoscan container. However, the container utilizes Python 3.12, which lacks VPI3 Python bindings. The latest available VPI3 bindings only support up to Python 3.10.
I can’t find any guide or source to compile such bindings. The VPI3 is available as cpp implementation.
Please help me setup the python-vpi3, my projects needs it. The last release of holoscan-container with python3.10 is 3.1.0
hello apb231,
please refer to [Release Notes - NVIDIA Docs], please try working with Holoscan SDK 3.9.0.
you may visit Holoscan Archive to download previous releases since you’re working with JP-6.
see-also [SDK Installation - NVIDIA Docs] to have python 3.10 installed.
Can you please provide more information?
Why 3.9.0 tp be specific?
I can see that every NCG container runs on python 3.12.
Should I install conda and python wheels on the barebone?
Sorry for the newbie question, I am relative new to the jetson systems.
If you could provide a,step-by-step guide, it could be amazing because I am very confused between versioning and multiple products: HSB, HSDK, Python, VPI3 and so on.
I have currently used SDK manager to install jetpack6.2.2 and the holoscan sdk to my jetson.
Then I followed the HSB setup guide for orin and ended up with a docker container where I can run the examples like linux_single_network_stereo_vb1940_player.py
I think that holoscan sdk is already installed on my host system thanks to sdk manager, I do not know which version.
hello apb231,
you may run sh docker/demo.sh and check the message,
for instance,
== NVIDIA Holoscan SDK ==
NVIDIA Holoscan SDK Version: 3.9.0
Container image Copyright (c) 2025, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
Refer to /opt/nvidia/legal for inherited CUDA and TensorRT container licenses and copyrights.
I am very sorry for the late reply. I was busy attending a class and taking notes.
Yes, I confirm that inside the holoscan container the SDK version is 3.9.0.
How should I proceed?
hello apb231,
you may add a Python 3.10 environment, as mentioned by [SDK Installation - NVIDIA Docs], Python wheels support 3.10.
do not reuse /opt/nvidia/holoscan/python/lib; those bindings are for Python 3.12. reinstall any Python packages your app needs into the py310 environment.
