"Holoscan Sensor Bridge software can be run on any system that is supported by NVIDIA Holoscan. For the best performance, an IGX system using ConnectX SmartNICs is recommended. In systems without ConnectX NICs, such as the Jetson AGX Orin, performance is limited by the host OS network stack.
Based on this statement, it appears that HSB should be able to run on any Holoscan-supported platform, not just IGX Orin or Jetson AGX Orin.
If anyone has a reference or setup guide or successful deployment on Orin NX/Nano, I would greatly appreciate any pointers.
HSB should be able to run on any Holoscan-supported platform, not just IGX Orin or Jetson AGX Orin - that is correct.
Nano and NX are derivatives of Jetson AGX Orin. As such, you can follow the AGX Orin instructions in the user guide to install HSB on these devkits. However, please note that these platforms have fewer compute resources, so you may experience lower performance, and some examples may not run successfully.
Our recommendation is to use the AGX Orin, which serves as the reference HSB development kit and is fully tested and verified. Nano and NX are not reference HSB platforms and, therefore, are not tested or validated by QA.
