I am trying to train a model under Homomorphic Encryption on the recommended Task09_Spleen dataset, following this notebook: clara-train-examples/Homomorphic_Encryption.ipynb at master · NVIDIA/clara-train-examples · GitHub.
I am able to train a model on the toy dataset (consisting of a single image) suggested in that notebook successfully, but if I try to change this to the Task09_Spleen dataset I get the following error on the client side:
File “<nvflare-0.1.4>/nvflare/apis/fl_component.py”, line 39, in fire_event
File “apps/fed_learn/trainers/client_trainer.py”, line 45, in handle_event
File “apps/fed_learn/trainers/client_trainer.py”, line 62, in initialize
File “<nvflare-0.1.4>/dlmed/utils/wfconf.py”, line 172, in configure
File “<nvflare-0.1.4>/dlmed/utils/wfconf.py”, line 167, in configure
File “<nvflare-0.1.4>/dlmed/utils/wfconf.py”, line 163, in _do_configure
File “apps/train_configer.py”, line 549, in finalize_config
File “/opt/monai/monai/data/decathlon_datalist.py”, line 128, in load_decathlon_datalist
return _append_paths(base_dir, is_segmentation, expected_data)
File “/opt/monai/monai/data/decathlon_datalist.py”, line 72, in _append_paths
raise TypeError(f"Every item in items must be a dict but got {type(item).name}.")
TypeError: Every item in items must be a dict but got str.
File “<nvflare-0.1.4>/nvflare/private/fed/client/fed_client.py”, line 127, in federated_step
File “apps/fed_learn/trainers/client_trainer.py”, line 90, in train
AttributeError: ‘ClientTrainer’ object has no attribute ‘trainer’
File “<nvflare-0.1.4>/nvflare/private/fed/client/fed_client.py”, line 229, in admin_run
File “<nvflare-0.1.4>/nvflare/private/fed/client/fed_client.py”, line 178, in run_federated_steps
File “<nvflare-0.1.4>/nvflare/private/fed/client/fed_client.py”, line 135, in federated_step
File “<nvflare-0.1.4>/nvflare/private/fed/client/fed_client_base.py”, line 217, in push_models
File “/opt/conda/lib/python3.8/multiprocessing/pool.py”, line 364, in map
return self._map_async(func, iterable, mapstar, chunksize).get()
File “/opt/conda/lib/python3.8/multiprocessing/pool.py”, line 771, in get
raise self._value
File “/opt/conda/lib/python3.8/multiprocessing/pool.py”, line 125, in worker
result = (True, func(*args, **kwds))
File “/opt/conda/lib/python3.8/multiprocessing/pool.py”, line 48, in mapstar
return list(map(*args))
File “<nvflare-0.1.4>/nvflare/private/fed/client/fed_client_base.py”, line 161, in push_remote_model
File “<nvflare-0.1.4>/nvflare/private/fed/client/communicator.py”, line 292, in submitUpdate
File “<nvflare-0.1.4>/nvflare/private/fed/client/data_assembler.py”, line 33, in get_contribution_data
File “<nvflare-0.1.4>/nvflare/private/fed/client/client_model_manager.py”, line 103, in read_current_model
TypeError: argument of type ‘NoneType’ is not iterable
This is my environment.json config file:
- DATA_ROOT: “/data_4FL_spleen/”
- DATASET_JSON: “/data_4FL_spleen/dataset.json”
- PROCESSING_TASK: “segmentation”
- MMAR_EVAL_OUTPUT_PATH: “eval”
- MMAR_CKPT_DIR: “models”
The dataset.json file is the file generated when running the download for Task09_Spleen inside the DownloadDecathlonDataSet.ipynb notebook. This config file is the same as the default except I have updated which datast.json file to point towards.
What do I need to do to get the model training under HE on this dataset? Do I need to edit the dataset.json file after it has been created? This error possibly suggests I do - if so what changes need to be made?
Thank you.
