I am getting started with two xavier agx dev machines and having trouble with the initial/full software stack install from SDK. Specifically I am wondering if there are any compatibility requirements between the host install machine and the xavier agx machines. I grabbed an old PC that was an extra to use as a dedicated Jetson Xavier AGX install machine however it has an older nvidia k620 graphics card and it is attached to two (2x) 1280x1024 monitors.
Is the base/host system in any way a limiting factor for software on the xavier agx? I am also looking to do a headless install (no monitors/desktop UI on the xavier agx). Is there an available headless software image for this machine?
I am using Jetpack 4.6 rev.3 and have been unable to install many of the Jetson SDK components.
I should also note that I have set the Jetson to install to nvme device and NOT the default emmc drivespace.
