Based on the provided context, I’ll address the issues and provide a comprehensive answer.
Issue 1: Ubuntu 2004 on AGX Orin and need to upgrade to Ubuntu 2204 with JetPack 5.1
The user has Ubuntu 2004 on their AGX Orin and wants to upgrade to Ubuntu 2204 with JetPack 5.1 to use the Arducam camera Hat, which is not compatible with Ubuntu 2004.
Issue 2: Unable to enter Recovery Mode on AGX Orin
The user is trying to enter Recovery Mode on their AGX Orin by holding the middle button, pressing and releasing the left button, and then releasing the middle button after 5-10 seconds. However, the device boots normally instead of entering Recovery Mode. The user has tried different USB cables, Ethernet cables, and using the USB-C port near the left of the pins, but nothing works.
Issue 3: SDK Manager unable to detect AGX Orin
The user has installed SDK Manager on their PC and is trying to flash the AGX Orin with the minimum components. However, the SDK Manager is unable to detect the AGX Orin, even when using an Ethernet cable or alternative USB cables.
Comparison with Force Recovery Mode (Concept)
The user’s attempt to enter Recovery Mode by holding the middle button, pressing and releasing the left button, and then releasing the middle button after 5-10 seconds is similar to the Force Recovery Mode (Concept) described in the context. However, the user’s method is not working, and the device boots normally instead.
Possible Solution
To enter Recovery Mode on the AGX Orin, the user can try using the sudo command instead of pressing buttons. The exact command is not specified in the context, but it might be something like sudo reboot recovery. This command can be executed on the AGX Orin terminal or through the SDK Manager on the PC.
If the user is still unable to enter Recovery Mode, they can try using the build_l4t_bup.sh tool to build a BUP image for the AGX Orin carrier board. This tool can be used to generate a Bootloader Update Payload (BUP) image, which can be used to recover the device.
Additional Information
The user’s WiFi connection on the AGX Orin has stopped working, which might be related to the issues they are experiencing. It is recommended to troubleshoot the WiFi connection separately to ensure it is working properly.
In summary, the user is experiencing issues with upgrading their AGX Orin to Ubuntu 2204 with JetPack 5.1, entering Recovery Mode, and detecting the device with SDK Manager. Possible solutions include using the sudo command to enter Recovery Mode, building a BUP image using the build_l4t_bup.sh tool, and troubleshooting the WiFi connection.
