I’m using 15.3 and the following code snippet
!$acc data copy(thermal_energy_updated), copy(planetary_thermal_energy), copy(surface_thermal_energy), &
!$acc& copy(thermal_energy_current)
time = start_time
call time_profiling_ini()
call getTime(t_start_output_cycle)
call getTime(t_start_output_cycle_w_io)
do while (.true.)
if (modulo(time + 0.001d0, output_timestep) < 0.01d0) then
call write_data(thermal_energy_current, "thermal_energy", time)
end if
call run_physics(thermal_energy_current, surface_thermal_energy, planetary_thermal_energy)
if (use_c) then
!$acc host_data use_device(thermal_energy_current,thermal_energy_updated)
call diffuse_c(thermal_energy_updated, thermal_energy_current, nx, ny, nz)
!$acc end host_data
else
call diffuse (thermal_energy_updated, thermal_energy_current)
end if
thermal_energy_temp => thermal_energy_updated
thermal_energy_updated => thermal_energy_current
thermal_energy_current => thermal_energy_temp
time = time + timestep
end do
!$acc end data
compiles fine, but the same one with enter/exit data does not:
!$acc enter data copyin(thermal_energy_updated), copyin(planetary_thermal_energy), copyin(surface_thermal_energy), &
!$acc& copyin(thermal_energy_current)
time = start_time
do while (.true.)
end if
if (use_c) then
!$acc end host_data
else
end if
if (time > end_time) then
!$acc exit data copyout(thermal_energy_updated), copyout(planetary_thermal_energy), copyout(surface_thermal_energy), &
!$acc& copyout(thermal_energy_current)
return
end if
end do
Compiler output:
pgf90 -Mcuda=cc3x -fast -ta=nvidia,cc3x -Minfo=accel,inline,ipa -Mneginfo -DGPU -c simple_weather.f90 -o simple_weather.o
PGF90-S-0528-Argument number 1 to diffuse_c: device attribute mismatch (simple_weather.f90: 97)
PGF90-S-0528-Argument number 2 to diffuse_c: device attribute mismatch (simple_weather.f90: 97)
0 inform, 0 warnings, 2 severes, 0 fatal for simulate
Am I guessing correctly that this was fixed somewhere in between 15.3 and 15.7? At least I’ve seen that working on 15.7 with pgc++ at the Lugano Hackathon.
